Visitor tony_obrien
Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted
I get the following error when trying to generate a .bit file for an example design using the 10/25G Ethernet IP core.
  • [Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted: DUT/inst/i_xxv_ethernet_4_top_0/i_xxv_ethernet_4_CORE (xxv_ethernet_4_xxv_ethernet_v1_3_0_mac_baser_axis_hsec_cores)
I have looked at previous Answer records which recommend resetting and Regenerating output products. This hasn't worked for me. And my license is correct.
What I cannot understand is: I have a project that contains the Eth core and that will complete correctly already. However my example design project that contains the same core will not generate a bit file.
I am using Vivado 2016.2.
Any help would be greatly appreciated.
Visitor tony_obrien
Re: Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted
Hi @vijayak
I regenerated the example from scratch and now it is working correctly.
Thank you for your help.
Tony
Hi @tony_obrien
Can you please attach the license manager screenshot that shows your IP license?
Thanks,Vijay
Visitor tony_obrien
Hi Vijay,
Is this what you require?
Tags (2)
Hi @tony_obrien,
It can happen if you have only design linking license.
Please share the output xinfo.txt of below Tcl command:
report_environment -file xinfo.txt
Arpan
Visitor tony_obrien
Hi @arpansur,
The file is attached. However, I'm not sure if this is the problem. I am able to generate a .bit file with another project that also contains the same core.
Tony
Hi @tony_obrien
Looks like you have valid license.
1) Can you try removing the IP from the project and add it again?
2) Also try creating a IP example design and see if you are able to get through.
Thanks,Vijay
Visitor tony_obrien
Hi @vijayak
Tony
