Visitor dory96
Cosimulation freeze, SDK not updating
Hi guys,
Some background:
I'm trying to use Zedboard as an acceelerator (run software on ARM then pass computational intensive parts to the FPGA). I have designed an IP Core in Vivado HLS, connected it to the ARM using a block diagram in Vivado and afterwards exported to the SDK. After writing the code in the SDK I noticed that an array, passed as argument, is not modified after running through the FPGA, so I stripped my design A LOT and ended up with this:
The cosimulation freezes when trying to use it against a very simple code (see below). The C simulation is fine. I've tried other values for depth as well.
I have this code in Vivado HLS. Please nevermind name of variables, I kept messing with the code hoping that I'll finally find a solution, but I didn't.
void interpreter_loop(int *instructions,
int *constants, int *sizes,
int *output){
#pragma HLS INTERFACE s_axilite port=return bundle=CONTROL_BUS
#pragma HLS INTERFACE m_axi depth=1000 port=instructions offset=slave bundle=INSTRUCTIONS
#pragma HLS INTERFACE m_axi depth=1000 port=constants offset=slave bundle=CONSTANTS
#pragma HLS INTERFACE m_axi depth=1000 port=sizes offset=slave bundle=SIZES
#pragma HLS INTERFACE m_axi depth=1000 port=output offset=slave bundle=OUTPUT
// xilly_puts("Hello, world\n");
int x = 1;
memset(sizes, 1, sizeof(int));
And I have this code in my test_banch:
int *output);
int main(void)
int input, instr, sizes, output;
output = 0;
int result;
memset(&result, 1, sizeof(int));
interpreter_loop(&input, &instr, &sizes, &output);
if (sizes == result){
// printf("succes\n");
return 0;
} else{
// printf("fail\n");
return 1;
My questions are:
1) What exactly is depth (note that I have a very strong C background, but minimal when it comes to FPGAs)? In my understanding, in order for HLS to be able to correctly synthetize the design I need to tell the length of the vector as depth argument (say I have 2 elements in vector then I say depth 2).
2) Any idea why that stalls in cosimulation? It doesn't even fail, it just freezes, and if I try to stop it then the who HLS IDE freezes.
3) Any idea why that code won't show any modification to the sizes argument when running on the Zedboard?
By the way, I'm using Vivado 2018.3.
Best,
Dorin
Visitor dory96
Re: Cosimulation freeze, SDK not updating
If it helps, this is my block diagram
Visitor dory96
In case anybody else encounters this problem, on number 3 I managed to find the solution:
The ARM Core doesn't know that something else might modify the data in the RAM, so it takes the data from the cache, even though it is outdated. The solution was to force a cache flush in the code running on the ARM Core.
It turns out that the cosimulation freezing doesn't mean than the hardware design is wrong, but I still don't understand why it freezes. Maybe it is a bug.
