Visitor ritodoji
Cropping image function using HLS
Hi everyone,
I'm new in HLS, I dont know how to implement a crop function using HLS because I usually use crop function from Cv2 or Pillow. And now, I want to know how to do it and any document I should read. I have already read Video Beginner Series 17 about Crop video but when I try change condition to crop then the log always loop this :
"WARNING: Hls::stream 'hls::stream<ap_axiu<24, 1, 1, 1> >.2' is read while empty, which may result in RTL simulation hanging."
Here my code changed :
#include "video_crop.h"
//Top Level Function
void video_crop(AXI_STREAM& s_axis_video,AXI_STREAM& m_axis_video, int hsize_in, int vsize_in)
#pragma HLS INTERFACE axis register both port=s_axis_video
#pragma HLS INTERFACE axis register both port=m_axis_video
	ap_axiu<24, 1, 1, 1> video;
	//AXI_STREAM video1;
	for(int i = 0; i < vsize_in ; i ++)
	         for(int j = 0; j < hsize_in ; j ++)
	        	 	 s_axis_video >> video;
	        	 	 if( i >vsize_in/2  )
	        	 		 	 	 m_axis_video << video;
// And testbench file :
#include <hls_opencv.h>
int main (int argc, char** argv) {
	// Load data in OpenCV image format
	IplImage* src=cvLoadImage("13x.jpg");
	//Get input Image size
	CvSize size_in;
	size_in = cvGetSize(src);
	//Set output image size
	CvSize size_out;
	size_out.width = size_in.width;
	//size_out.height = size_in.height-size_in.height/2;
	size_out.height = size_in.height/2;
	//Create Destination image
	IplImage* dst = cvCreateImage(size_out, src->depth, src->nChannels);
	//Create the AXI4-Stream
	AXI_STREAM src_axi, dst_axi;
	// Convert OpenCV format to AXI4 Stream format
	IplImage2AXIvideo(src, src_axi);
	// Call the function to be synthesized
	video_crop(src_axi, dst_axi,size_in.width,size_in.height);
	// Convert the AXI4 Stream data to OpenCV format
	AXIvideo2IplImage(dst_axi, dst);
	// Standard OpenCV image functions
	cvSaveImage("/home/rito/Desktop/HLS_practice/XVES_0017/13x_2.jpg", dst);
	cvReleaseImage(&src);
	cvReleaseImage(&dst);
	return 0;
Thanks in advance for your help.
Best regards
Hung
Scholar u4223374
Re: Cropping image function using HLS
I haven't fully verified this, but I think it'll be because you've dropped TUSER. Normally TUSER = 1 for the first pixel in a frame, and TLAST = 1 for the last pixel in each line. However, with the cropping you're doing, you've cut out the only place where TUSER = 1 (by only taking the second half of the image).
Also, your maths is off slightly. Take a very small image that's 8x6 pixels. You're only copying pixels when (i > vsize_in/2), which is to say i > 3. That means that in this example you would only copy lines 4 and 5, whereas I think you were expecting to use 3, 4, and 5.
Scholar u4223374
Visitor ritodoji
Thank you so much, from your help I see my problem here :
+ I didnt set video.last = 1 when it done
I tried it and my problem has gone !!!!! Yay
Once again, thanks you!!
