Csim error in HLS 64k FFT ip
I use HLS fft ip implement 64K fft, but the csim error. when i debug the project, the code crack at '__chkstk_ms' as following
BTW, when set the fft length at  32k, 16k,8k,512, the csim run right ,and the result is right(compared to matlab calulate result)
the project file in the attachments
Re: Csim error in HLS 64k FFT ip
any one can help me?
help me please
up
[ Edited ]
@hbbatistuta probably 64K size is causing a stack overflow as you are allocating large buffers on the stack, try increasing your stack size. Which OS are you using?
@muzaffer
    Thank you for your reply
    I use HLS 2016.3, Windows 7. My PC have 64G memory
