Observer h.hamil
Detect falling edges to generate impulsions
Using Vivado_HLS I’m trying to generate impulsions (signal_out) of same amplitude and width at every falling edge of signal_in.
this is the code for the detection of falling edges of signal_in:
if (((*signal_in)==1) && (*signal_in ==0))
*signal_out <= '0';
*signal_out <= '1';
*signal_out <= '0';
The simulation result (shown by wave viewer) is attached bellow.
Could anyone provide helpful suggestions?
Voyager
Voyager
Re: Detect falling edges to generate impulsions
@h.hamil,
The first step of an HLS design is to create C/C++ code that performs the user's alogrithm.  There is no way that your if statement ("if (((*signal_in)==1) && (*signal_in ==0))") will ever be true.  "Signal_in" can not be both "1" and "0" at the same moment in time.  This will not work in Verilog/VHDL either.
Edge detection requires comparing a signal at two different points in time.  That requires the design to hold on to old values to compare against the new.  In RTL, that would be a register.  There are a couple of ways to do it in HLS depending upon your design methodology.
If you are using a Frame based method you would need something like:
for(i=0;i<N;i++) {
    if(signal_in[N]==1 && signal_prev==0) {
        signal_out[N] = 1;
    else {
        signal_out[N] = 0;
    signal_prev = signal_in[N];
If you are using a Sample based method then you would need something like:
static data_t signal_prev;
if(signal_in==1 && signal_prev==0) {
    signal_out = 1;
else {
    signal_out = 0;
signal_prev = signal_in;
I would recommend looking at the following HLS User Guides:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug902-vivado-high-level-synthesis.pdf
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1270-vivado-hls-opt-methodology-guide.pdf
https://www.xilinx.com/support/documentation/sw_manuals/ug1197-vivado-high-level-productivity.pdf
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Observer h.hamil
Hello tedbooth,
I tried the following code and here is no error when running C simulation + C synthesis but,  unfortunately i did not get the signal_out which still zero.
Any more idea? Thanks
if(signal_in==0 && signal_prev==1) {
    signal_out = 1;
else {
    signal_out = 0;
