Double and float vector datatypes - OpenCL on HLS and HLS Testbench
Hi everyone! I would like to fix an issue on the CTestbench for an OpenCL kernel I should test and run on a ZedBoard. I am new with this topic: excuse my naïf questions and mistakes.
As suggested I am debugging everything using the Simulation in Vivado HLS.
I am able to pass to my kernel all float, double, int, int* arguments but not float4 and double4 data types (both constant values and __global pointers).
I have included <clc.h> in the kernel .cl file, but I am not able to transfer from the C-testbench some valid inputs:
1) I have tried to pass to my kernel (__global float4*) a float array (4 times the length of the float4 I need) but I get some errors, specifically:
eval.c:177:1: error: unknown type name 'ap_private'
ap_private<128, true> hls_PartSet_OC_i128_OC_i128_OC_i32_OC_i32_OC_i32(ap_private<128, true> , signed int , signed int , signed int ) __ATTRIBUTE_WEAK__;
eval.c:177:11: error: expected identifier or '('
eval.c:178:17: error: unknown type name 'ap_private'
void evaluation(ap_private<128, true> *gmem, signed int *group_id_2e_x, signed int *group_id_2e_y, signed int *group_id_2e_z, signed int *global_offset_2e_x, signed int *global_offset_2e_y, signed int *global_offset_2e_z, signed int *N, signed int *globalX, signed int *istart, signed int *ppGpus, signed int *Bfactor, signed int *dimension, signed int *next, signed int *loc_time, signed int *TIME, signed int *EPS, signed int *pl_core, signed int *pl_mass, signed int *rscale, signed int *mscale);
eval.c:178:27: error: expected ')'
eval.c:178:16: note: to match this '('
eval.c:179:22: error: unknown type name 'ap_private'
void _OC_evaluation7(ap_private<128, true> *, l_struct_OC_three_tuple_t *, l_struct_OC_three_tuple_t *, l_struct_OC_evaluation_args_t *);
eval.c:179:32: error: expected ')'
eval.c:179:21: note: to match this '('
eval.c:258:1: error: unknown type name 'ap_private'
Should I include something to my testbench? Can it handle vector data types? I have seen the simulator is very strict wrt SDK or others IDE on how to add source files. Where should I place the files/headers and the #include directives?
The example in the documentation is for int arrays and not for vector data types.
2) What about __local float4 and __local double4 inputs of my kernel?  Is it OK for Vivado HLS to handle __local arrays in the prototype of the OpenCl kernel?   How should I handle them in the testbench?  Please note that I am gradually adding these interfaces, thus the before-mentioned (1) problem is present even without these __local input parameters.
Thanks in advance for your help, suggestions and answers!
Cheers, Marco :)
