Enforcing parallelism from existing software design
As part of a larger project we have defined a parallel design, which we want to translate into an FPGA design.
The Vivado tools are aimed at parallelizing sequential code, but we want to ahcieve the parallelization already described from our design. We are well aware that the synthesization process parallelizes the code, but is it possible to write C-code in a specific way that enforces our existing design?
For the interested: This task is part of a larger project, in which we have defined a large CSP network which we want to automatically translate into hardware.
Thanks in advance
/Frisch
Re: Enforcing parallelism from existing software design
You can run multiple copies of the identical functions or different functions within a top function. Given correct directives and if the tasks are not interdependent vivado should be ab le schedule them in parallel. The top fuction would just be the wrapper for the indivudual tasks.
Vivado HLS can be one option for your need, please go throug below UG for more details..
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug902-vivado-high-level-synthesi...
Hope this helps.
Vanitha.
Thank you for your swift response.
However, after briefly looking through the document, we still find that all parallelization are based on sequential C/C++ programs. Instead we want to define several 'top-level' processes.
A simple example could be a Producer process, generating data for a Consumer process -- both of which are executed in parallel. This is easy to do sequentially and then have Vivado HLS parallelize it during synthesization, but as we want to enforce our existing design we want to define the C/C++ code with multiple parallel 'top-level' processes.
Is this doable and if so, where can we find an example of this?
Thanks again
/Frisch
I do not think HLS can have multiple top level processes at once, moved it appropriate board where it can be answered better.
Vanitha.
Thank you.
As a follow up: what is the easiest way to assert that Vivado HLS scheduled the tasks the way we intended it to?
Well you can always see that from the perfomance of the synthesized design. If you now what to expect you can immetately conlcuded things on the scheduling just by the latency. Additionally HLS includes a scheduling graph viewer to see exactly how the tool scheduled the various operations and how long they take.
Something that you need to read about in UG902 is the DATAFLOW pipelining.
And another comment is that if the functions that you want to run in parallel are completely independant, then they should be made independant.. so they can be used really independantly in the system.
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Thank you both :)
You gave us some valuable hints and some food for thought and our project is coming along beautifully.
We appreciate the fast responses a lot.
