Newbie jrausche
FFT in Pipelined Streaming I/O with no Cyclic Prefix Insertion Mode
I would like to implement a realtime 4k FFT, but could not get an II=4096 realized. The solution below produces an II=12429.
Is there a way to get this done?
Best Regards,
Juergen
struct config1 : hls::ip_fft::params_t {
    static const unsigned ordering_opt = hls::ip_fft::bit_reversed_order;
    static const unsigned max_nfft = FFT_NFFT_MAX;
    static const bool hast_nfft = false;
    static const bool ovflo = false;
    static const unsigned arch_opt =  hls::ip_fft::pipelined_streaming_io;
    static const unsigned complex_mult_type = hls::ip_fft::use_mults_resources;
    static const unsigned stages_block_ram = 5;
    static const unsigned phase_factor_width = FFT_PHASE_FACTOR_WIDTH;
    static const unsigned butterfly_type =  hls::ip_fft::use_xtremedsp_slices;
void fft_4k(complex<float> fft_in[4096],complex<float> fft_out[4096])
#pragma HLS dataflow
 bool dir = true;
 bool ovflow[1];
 config_t fft_config;
 status_t fft_status;
 fft_config.setDir(dir);
 fft_config.setSch(0x2AB);
 // FFT IP
 hls::fft<config1>(fft_in, fft_out, &fft_status, &fft_config);
Re: FFT in Pipelined Streaming I/O with no Cyclic Prefix Insertion Mode
Check
http://www.xilinx.com/support/answers/59678.html
brucey
Check
brucey
Newbie jrausche
Thank you for the feedback. I have already tried:
cosim_design -setup -rtl vhdl -tool modelsim
export_design -evaluate vhdl -format ip_catalog
But I also get the same II in the waveform as shown in the Vivado HLS report.
Juergen
Newbie jrausche
By forcing the right signal to '1' in Questasim I have managed to identify an II of 4097.
Best Regards,
Juergen
