Scholar jprice
Fixed Point and Division
I was looking over the HLS user guide to determine what the results of division were for fixed point types. The guide states:
For result = Val2 / Val1:
    This shows the division of Val1 and Val2. To preserve enough precision:
            • The integer bit-width of the result type is sum of the integer = bit-width of Val1 and the fraction bit-width of Val2.
            • The fraction bit-width of the result type is sum of the fraction bit-width of Val1 and thewhole bit-width of Val2.
So I try the following code below in a C testbench:
   ap_fixed<29,13> t2 = 9.94989;
   cout << t2 << endl;
   cout << ap_ufixed<2,1>(1.0) / t2 << endl;
t2 outputs 9.94987 as expected. The result however is truncated to 0 which does not make sense from the above description. If I give me numerator more fractional bits then my expected result begins to materialize. I feel like either HLS or the documentation is in error and I'm not sure which. Can anyone shed some light on what I'm observing? I'm able to work around it for my design but this is unexpected behavior and I'd like to understand it more.
Note that the excerpt is taken from the 2016.2 user guide and the C simulation is run in 2016.2.
Scholar u4223374
Re: Fixed Point and Division
Looks like an error in UG902. If you have a look on page 668 and 669, you'll find the following statement (with regards to the C++ fixed-point types):
For  ap_[u]fixed  types, the fraction is no greater than that of the dividend.
Which is exactly what you're seeing.
Scholar u4223374
Scholar jprice
Thanks! I missed that. That makes sense, hopefully they'll catch that and update it.
