Visitor aperloff
[HLS 2018.3/2019.1] 'use of undeclared identifier' when using cflags
I'm hoping someone can help me out with this problem as it has me completely stumped. I have a design which works perfectly in Vivado 2018.2. However, if I change nothing else, but switch to Vivado 2018.3 or 2019.1 I recieve error messages like those in [1]. Vivado seems to be ignoring the cflags defined in the tcl file, at least during synthesis (see [2]). It finds the TEST preprocessor macro in the testbench during csim, but not the HLS_pipeline_II macro during csynth. Does anyone have an idea why this is happening? I have included some information about my setup in [3].
Alexx
[1]
ERROR: [HLS 214-124] use of undeclared identifier 'HLS_pipeline_II': <path to file>/firmware_file.cpp:103
[2]
# Get any additional configuration variables necessary
source config.tcl
# Open the project, don't forget to reset
open_project -reset proj_${var1}_${var2}
# Set the top function and add the files to the project
set_top ${var3}
add_files firmware_file.cpp -cflags "-DTEST${var1} -std=c++0x -DHLS_pipeline_II=${var4}"
[3]
Vivado HLS: 2019.1
OS: CentOS Linux release 7.6.1810 (Core)
CSIM Compiler: GCC
