HLS: GUI BUG? : default Dialog box layouts too small
See the screen shots… Using 2018.3 (and 2018.2) on Windows.
Many dialog boxes require you to resize them in order to see all the controls
Note: Vivado does not seem to have this issue. Also, I am using a 4K display (if that makes a difference)
Any way to adjust this to correctly show the complete dialog boxes?
Re: HLS: GUI BUG? : default Dialog box layouts too small
Yes, I would say it is a bug... the cause is that Vivado HLS does that correctly handle when the display text scaling factor is not 100%. (Which is pretty normal for a 4K display)
