Scholar pedro_uno
HLS arbitrary precision floating point math?
Hello All,
I am building some blocks in HLS that require floating point math.  Early experiments indicate that single precision floating point accumulates unacceptable errors. For example, I tested a 4x4 matrix inversion block by filling it with random numbers taking the inversion and then mutliplying the result by the original to get back an identity matrix.
I then checked the resulting identity matrix against an ideal identity matrix and recorded the maximum error.  On a run of 1 million matrix inversions, single precision math gave a maximum error of  about 1.3e-1.  Double precision math gave an error of about 1e-10.
Going from single precision to double precision doubled the logic utilization and doubled the latency.
I know that the Xilinx floating point logicore blocks support arbitrary precision floating point numbers.  I am guessing that my algorithm doesn't need the full 56 bit mantissa of double precision but the 24 bits of single precision is too little.
I did not find any mention of it in UG902. Does HLS support arbitrary precision floating point types?
    Pete
DSP in hardware and software
Re: HLS arbitrary precision floating point math?
hello Pete,
<<Does HLS support arbitrary precision floating point types?>>
I don't think so, however you may be able to use the appropriate ap_fixed type?
you can maybe experiment with changing typedefs in your code; as you'll know with fixed size you'll have to allow for bitwidth expansion.
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
hello Pete,
- Hervé
SIGNATURE:
Do you still have question? If not kindly close this post by selecting the answer which helped you as an Accepted Solution.
Debraj
