Newbie zhangkai
HLS axi master example warnings
When I open the example axi master project in Vivado HLS(Vivado2018.1 and Ubuntu16.04),and synthesis ,co-sim,the console displays these two warnings:
1.WARNING: [COSIM 212-369] AXI_master port 'a' has a depth of '50'. Insufficient depth may result in simulation mismatch or freeze.
2.WARNING: [XSIM 43-3431] One or more environment variables have been detected which affect the operation of the C compiler. These are typically not set in standard installations and are not tested by Xilinx, however they may be appropriate for your system, so the flow will attempt to continue.  If errors occur, try running xelab with the "-mt off -v 1" switches to see more information from the C compiler. The following environment variables have been detected:
    LIBRARY_PATH
Could you help me to resolve these two warnings?
Scholar xilinxacct
Re: HLS axi master example warnings
@zhangkai
The first warning can be resolved by using ...
#pragma HLS stream variable=<variable> depth=<int>
and specify the depth that would assure it can handle the worst case.
The second... follow the instruction in the warning message itself.
Hope that helps
If so, please mak as solution accepted. Kudos also welcomed. :-)
