Observer shakeelsultan
HLS fft_single example in streaming mode.
How can I run xilinx provided fft_single example in streaming mode?
I tried declaring [in, out ] ports of fft_top as streaming inputs. Though the design gets synthesized but I get a shifted output on each run.
Can anyone help please?
Re: HLS fft_single example in streaming mode.
Hey @shakeelsultan ,
We highly recommend the hls streaming library "hls_stream.h" and hls::stream<> types. I was able to rewrite the example to use streaming accesses as follows.
In the tesbench, replace the arrays with hls::stream types:
    //static cmpxDataIn xn_input[SAMPLES];
    hls::stream<cmpxDataIn> xn_input_stream;
    //static cmpxDataOut xk_output[SAMPLES];
    hls::stream<cmpxDataOut> xk_output_stream;
Fill the streams with the data in the testbench using << or .write():
//xn_input[line_no-5] = cmpxDataIn(input_data_re, input_data_im);
xn_input_stream <<  cmpxDataIn(input_data_re, input_data_im);
Read out the output stream. A little more refactoring here because you must only each streaming output once:
  //if (golden != xk_output[i].re)
cmpxDataOut res = xk_output_stream.read();
if (golden != res.real())
res.real() and res.imag() and compared and printed after that. If you don't add the .read(); line there, you could get up to 4 accesses to the stream, which could cause a co-sim failure.
The dummy_proc_[be/fe]() functions need slight changes as well:
void dummy_proc_fe() {
 for (i=0; i< FFT_LENGTH; i++) out[i] = in.read(); // out[i] = in[i];
void dummy_proc_be() {
for (i=0; i< FFT_LENGTH; i++) out.write(in[i]); //out[i] = in[i];
And then the funciton headers need to be changed to pass in pointers to hls::stream types:
void dummy_proc_fe(
    bool direction,
    config_t* config,
	hls::stream<cmpxDataIn> &in,
    cmpxDataIn out[FFT_LENGTH]);
void dummy_proc_be(
    status_t* status_in,
    bool* ovflo,
    cmpxDataOut in[FFT_LENGTH],
	hls::stream<cmpxDataOut> &out);
void fft_top(
    bool direction,
    hls::stream<complex<data_in_t> > &in,
    hls::stream<complex<data_out_t> > &out,
    bool* ovflo);
That's how I would recommend you change from fifo to streaming. Generally, it's not advised to just use the #pragma HLS STREAM directive because you need to carefully keep track of your reads and writes.
Nicholas Moellers
Xilinx Worldwide Technical Support
