HLS floor() bug
I think there's a bug in the hls_math library. Consider the code fragment below.
ap_fixed<10, 3, AP_TRN> a;
ap_fixed<10, 3, AP_TRN, AP_SAT_SYM> b;
int c;
c = floor(a);
c = floor(b); // compilation error
The line 'floor(b)' doesn't compile with the following error messages:
C:/Xilinx/Vivado/2018.2/include/hls_math.h:310:10: note: candidate: double hls::floor(double)
   double floor(double);
C:/Xilinx/Vivado/2018.2/include/hls_math.h:311:10: note: candidate: float hls::floor(float)
   float  floor(float);
C:/Xilinx/Vivado/2018.2/include/hls_math.h:312:10: note: candidate: half hls::floor(half)
   half   floor(half);
Is this in fact in the hls_math library? Or am I missing something?
Cheers
Re: HLS floor() bug
Hey @dsula,
The hls_math.h library only supports the first and second template parameters. This is stated in UG902 on page 242. However, it doesn't explicitly say that the third and beyond template parameters and not supported, and I've reported to the appropriate teams that this is confusing.
The reason c = floor( a ) compiles is that AP_TRN is the default, so ap_fixed<10, 3, AP_TRN> a is understood to be the same type as ap_fixed<10,3> a.
As a workaround, can you cast b to ap_fixed<10, 3> before calling floor()? ap_fixed<10,3> can hold values from -4 to ~3.99, so it is logically the same. The following code compiles successfully:
int c;
c = floor(a);
c = floor( ap_fixed<10,3> b).to_int() // no compilation error
Nicholas Moellers
Xilinx Worldwide Technical Support
Re: HLS floor() bug
Hey @dsula,
int c;
c = floor(a);
Nicholas Moellers
