Visitor mishiuss
HLS-systemC-Instantiating Modules
Hello! I'm beginner and I encountered a problem when I try run C Synthesis. I can't using ''new" for instantiating module.  How should I modify
my code(ppd.h)?
////fir.h
template<class T, int order>
SC_MODULE(fir)
SC_HAS_PROCESS(fir);
fir(sc_module_name name, T* _h) :sc_module(name), h(_h)
SC_METHOD(algorithm);
void algorithm() {...}
///ppd.h
#include "fir.h"
#define N 33
#define M 3
#define P 11
double** eMat(int rows, int columns, double *h) {....}
double* eVec(int row, int columns, double **Matrix) {.....}
class ppd : public sc_module
public:
//signals ....
double **Matrix;
double *tmpE;
double *h;
fir<double,P> *E[M];
SC_HAS_PROCESS(ppd) ;
ppd(sc_module_name name, double* _h, fir<double,P>) : sc_module(name), h(_h)
Matrix = eMat(M,P,h);
for (unsigned int i = 0; i < M; i++)
tmpE = eVec(i,P,Matrix);
E [i] = new fir<double,P>(sc_gen_unique_name("E"),tmpE);
E[i] ->CLK(CLK);
E[i] -> firIN(delay[i]);
E[i] -> firOUT(sum[i]);
void algorithm()
Olga
Re: HLS-systemC-Instantiating Modules
An SC_MODULE cannot be instantiated as new. Refer to page 319 of the document to modify your code accordingly: http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_3/ug902-vivado-high-level-synthesis.pdf
Debraj
