Visitor chrismantel
How to add C library path for Vivado HLS debugger?
I'm learning UG871, C validation, Lab1
When I run C validation and C synthesis, there's nothing run.
But when I start the debugger and step into the scentence with function 'cos', it shows the error information as follows:
Can't find a source file at "C:/repo/mingw-w64-crt-git/src/mingw-w64/mingw-w64-crt/math/cos.def.h"
So I went to github and found the folder mingw-w64-crt and clone it to my PC, add the folder to environment variable. However, the error still exists. How do I solve this?
Re: How to add C library path for Vivado HLS debugger?
HI @chrismantel ,
Can you please share your HLS version and OS version on which you are working ?
This would help us to check at our end if the issue is reproducible
Visitor chrismantel
Vivado HLS Version 2018.3
OS:
Windows 10
Version 1803 (OS Inner version 17134.648)
Hi @chrismantel ,
Thanks for sharing the info.
Although the error occurs what if you click on Step into option continuously ? Does it progress over the code with the values in variables window being updated ?
Visitor chrismantel
Yes, it occurs every time I step into that expression which includes 'cos'.
However, if I do C simulation without launching the debugger, nothing is wrong and err_cnt is 0, indicating sw_result is the same as hw_result.
Hi @chrismantel ,
It seems to be an issue with windows platform alone as I am able to reproduce it in Vivado 2018.3 on windows alone but not on linux.
I will be checking with the internal latest Vivado build and will share my observations.
