Visitor lhochstetter
LED pulse width modulation
Hi everyone,
me once again with another problem (predecessor can be found here): I want to drive 8 LEDs at different frequencies and came up with the following code:
#include <stdbool.h>
#include "led_controller.h"
#include "../../shared/data_structures.h"
unsigned char led_o;
struct led_bitfield {
	unsigned char led_0 : 1;
	unsigned char led_1 : 1;
	unsigned char led_2 : 1;
	unsigned char led_3 : 1;
	unsigned char led_4 : 1;
	unsigned char led_5 : 1;
	unsigned char led_6 : 1;
	unsigned char led_7 : 1;
union leds {
	struct led_bitfield led_bits;
	unsigned char led_mask;
void apply_led_config(struct led_config config[LED_COUNT])
	static unsigned int ticks[LED_COUNT] = { 0, 0, 0, 0, 0, 0, 0, 0 };
	static bool toggle[LED_COUNT] = { 0, 0, 0, 0, 0, 0, 0, 0 };
	static union leds led_states;
	if (config[0].threshold_on == ticks[0] && toggle[0]) {
		toggle[0] = 0;
		ticks[0] = 0;
	} else if (config[0].threshold_off == ticks[0] && !toggle[0]) {
		toggle[0] = 1;
		ticks[0] = 0;
	if (0 == ticks[0]) {
		led_states.led_bits.led_0 = toggle[0];
	ticks[0]++;
	led_o = led_states.led_mask;
The code contained in /'s (first LED) is replicated for the remaining 7 LEDs.
My idea is quite simple: each LED has its own configuration (struct led_config config[LED_COUNT], led_config is a simple struct containing two unsigned ints: threshold_on and threshold_off) which allows to define a number of ticks the LED is lit / dark.
I have 8 independent counters (ticks), which are set to 0 when the corresponding LED is toggled.
The bit field / union holds the led states inbetween to clock signals.
 writes the LED states to the physical LED pins.
I did achice II=1 to count the clock cycles but my execution time is to high
	WARNING: [SCHED 204-21] Estimated clock period (11ns) exceeds the target (target clock period: 10ns, clock uncertainty: 1.25ns, effective delay budget: 8.75ns).
WARNING: [SCHED 204-21] The critical path consists of the following:
    'phi' operation ('toggle_0_loc', led_controller.c:32) with incoming values : ('toggle_0_load', led_controller.c:32) (0 ns)
    'bitconcatenate' operation ('tmp_7', led_controller.c:41) (0 ns)
    'select' operation ('led_states_loc', led_controller.c:40) (1.37 ns)
    'select' operation ('led_states_new_1', led_controller.c:55) (1.37 ns)
    'select' operation ('led_states_new_2', led_controller.c:70) (1.37 ns)
    'select' operation ('led_states_new_3', led_controller.c:85) (1.37 ns)
    'select' operation ('led_states_new_4', led_controller.c:101) (1.37 ns)
    'select' operation ('led_states_new_5', led_controller.c:116) (1.37 ns)
    'select' operation ('led_states_new_6', led_controller.c:131) (1.37 ns)
    'select' operation ('led_states_new_7', led_controller.c:146) (1.37 ns)
 I understand that the if's which assign new values in the bit field are the issuse, but I don't know how to access the bits of the unsigned char I'm using to write the LED states to the physical pins idependently and concurrently.
Any ideas how I can meet the target clock while maintaining II=1? (I'd also like to keep the unsigned char for easy writing to the LEDs - however if there is a "better" way like using a bitfield all the way etc. which will result in a single port on the IP I'll go with it ... and HDL isn't an option unfortunately)
Re: LED pulse width modulation
use DDS core
http://www.xilinx.com/support/documentation/ip_documentation/dds_compiler/v6_0/pg141-dds-compiler.pdf
Thanks and Regards
Balkrishan
Thanks for your reply, I skimmed the linked document. The DDS core is a little bit overkill for what I intend to do.
I managed to get the time down to 8.9ns while maintaining II=1
bool led_o[LED_COUNT] = { 0, 0, 0, 0, 0, 0, 0, 0 };
void apply_led_config(struct led_config config[LED_COUNT]) {
	for (char i = 0; i < LED_COUNT; i++) {
		if (config[i].threshold_on == ticks[i] && toggle[i]) {
			toggle[i] = 0;
			led_o[i] = 0;
			ticks[i] = 0;
		} else if (config[i].threshold_off == ticks[i] && !toggle[i]) {
			toggle[i] = 1;
			led_o[i] = 1;
			ticks[i] = 0;
		ticks[i]++;
set_directive_array_partition -type complete -factor 8 -dim 1 "apply_led_config" config
set_directive_interface -mode s_axilite -bundle a "apply_led_config" config
set_directive_pipeline -II 1 "apply_led_config"
set_directive_array_partition -type complete -factor 8 -dim 1 "apply_led_config" led_o
set_directive_interface -mode ap_none -register "apply_led_config" led_o
The code is pretty straight forward.You need the toggle array, otherwise VHLS complains when performing reads / writes on led_o IIRC due to data races.
I used a xlconcat IP Core to combine the led_o_i[0:0] ports to one led_o[7:0] port.
Interesstingly enough, Vivado doesn't complain about timing issues. How accurate are the VHLS estimates?
