Participant haggaie
Mixing AXI slave and pipeline mode
I got this warning when running co-simulation:
@W [SIM-376] This design mixes AXI slave interface and pipeline mode, which could potentially result in simulation dead-lock and/or get mismatching results.
I think I'm also getting the associated potential deadlock. The simulation verilog wrapper attempts to generate reads for all the outputs of my design, and waits until they are all available before writing the next "start" command. Because the outputs are not generated on every call, I'm getting a deadlock.
Is that it?
Scholar u4223374
Re: Mixing AXI slave and pipeline mode
Could you post the code, or at least the function header + interface pragmas? I've never seen this one before, and I thought I'd seen pretty much everything that HLS could produce.
Participant haggaie
I'll try to post some code. I believe I solved the actual deadlock though: I have a dataflow design with multiple FIFO interfaces. In some places I didn't check that the FIFOs were not full and I think that was the cause. The warning is still there though.
Participant haggaie
Okay. Here's an example. (It might be a little more complex than needed, I just copied it from another MWE I recently posted):
#include <hls_stream.h>
struct s {
    int a;
    int b;
void link(hls::stream<s>& in, hls::stream<s>& out)
#pragma HLS pipeline enable_flush
    if (in.empty() || out.full())
        return;
    out.write(in.read());
/* Top HLS function */
void top(hls::stream<s>& in, hls::stream<s>& out)
#pragma HLS dataflow
#pragma HLS interface s_axilite port=return
    static hls::stream<s> streams[2];
    link(in, streams[0]);
    link(streams[0], streams[1]);
    link(streams[1], out);
/* Testbench */
int main(int argc, char **argv)
    s example = { 1, 2 }, result;
    hls::stream<s> input, output;
    input.write(example);
    top(input, output);
    top(input, output);
    top(input, output);
    result = output.read();
    return !(result.a == example.a && result.b == example.b);
