Observer mh9840
Need help with Floating point data stream & arithmetic
Hello all, I need help with using Floating point data with HLS.
I've designed a IP that reads in (signed) float data, does a convolution of float data input, and write the result as float data. But it turns out I can't normally do floating point arithmetic in HLS. It's suggested that I use fixed point data, but I'm having trouble understanding how to use it for my case.
So far I was able to write the testbench to send float data in uint32_t format using these definitions :
typedef ap_axis <32,1,1,1> AXIS;      // hls::stream
typedef hls::stream<AXIS> STREAM_T;   //
typedef union {   // float32<->int32 convert
	int u;
	float f;
} uni;
Now I'm guessing that I should convert uint32_t format to fixed point, and do the convolution using fixed point variables. But I'm completely new to using fixed point data types. I've looked into ug902 manual, but still not sure how I should use it.
What I want to do would look like this :
output = input1 * input 2
// input1 (-1,1), input2 (-1,1)
Are there examples of converting float data input to fixed point and doing arithmetics?
Thanks in advance.
Re: Need help with Floating point data stream & arithmetic
Hey @mh9840 ,
Olivier has posted a nice simple example of how to pass data as an integer and then interpret it as a float here:
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/Float-numbers-with-hls-stream/td-p/942731
I think something like the following is what you're looking for:
typedef hls::stream<int> STREAM_T;
	int u;
	float f;
} uni;
void top( STREAM_T& in1, STREAM_T& in2, STREAM_T& out) {
	uni input1, input2, output;
	in1 >> input1.u;
	in2 >> input2.u;
	output.f = input1 * output2;
	out << output.u;
Let me know if that helps,
Nicholas Moellers
Xilinx Worldwide Technical Support
Hey @mh9840 ,
	int u;
	float f;
} uni;
	in1 >> input1.u;
	in2 >> input2.u;
	out << output.u;
Nicholas Moellers
