Participant eewse
No output for a simple image filter used in HLS dataflow
void top_function(......) {
#pragram HLS dataflow
function1(....);
function2(....);
function3(.....);
function4(....);
This function will fail and produce no output if the number of functions is more than three. Since there are no error during compilation, does anyone know what are the errors that lead to no output.
Scholar u4223374
Re: No output for a simple image filter used in HLS dataflow
Does it fail specifically when the number of functions is more than three? Or is it whenever the fourth function is enabled? For example, if you replace the call to function4 with a second call to function3, does it work?
Have you run a simulation with this? A cosimulation?
And, of course, can you post the code? Even just the full code for top_function with all the variable names changed would be a good start, since we can then see how the data flows through each of your other functions.
