Observer pupkin
Numerous problems with generated HDL
Greetings,
Recently we've been experiencing numerous issues with HLS generating buggy verilog causing co-simulation to hang or to produce wrong results. Most of the time they appear to be caused by broken control state machines.
Here is one example I managed to isolate. The idea is func_a() picks up interesting bits from input stream and sends it to func_b() for the processing though a FIFO. The code as shown hands co-simulation. If I comment out PIPELINE pragma in func_b(), everything works, but func_b() takes unacceptably long time for each iteration.
I appreciate any suggestions.
#include <hls_stream.h>
struct Q
    int  x;
    bool eof;
void func_a(hls::stream<int>&   sin, hls::stream<Q>& queue)
    Q q;
    for (int i = 0; i < 100; i++)
        int x = sin.read();
        if (i >= 10 && i < 15)
            q.x = x;
            q.eof = false;
            queue.write(q);
    q.x = 0;
    q.eof = true;
    queue.write(q);
void func_b(hls::stream<Q>& queue, hls::stream<int>&   sout)
    for(;;)
#pragma HLS PIPELINE II=1
        Q q  = queue.read();
        if (q.eof)
            break;
        int y = q.x/3;    // lengthy operation
        sout.write(y);
void hls_top(hls::stream<int>& sin, hls::stream<int>& sout)
#pragma HLS DATAFLOW
    hls::stream<Q> queue;
#pragma HLS STREAM variable=queue depth=1000
    func_a(sin,  queue);
    func_b(queue, sout);
and a testbench
#include <stdio.h>
void hls_top(hls::stream<int>& sin, hls::stream<int>& sout);
int main()
    hls::stream<int> sin, sout;
        sin.write(i);
    hls_top(sin, sout);
    while (!sout.empty())
        printf("%d\n", sout.read());
Observer pupkin
Re: Numerous problems with generated HDL
OK as promised, here is another co-sim failure case:
#include <hls_fft.h>
typedef hls::ip_fft::config_t<hls::ip_fft::params_t> config_t;
int func_a
    config_t& config,
    int const table[1]
    return config.getDir() ? table[0] : -1;
void func_b
    int const           table[1],
    config_t    config;
#pragma HLS data_pack   variable=config
#pragma HLS stream      variable=config
    config.setDir(1);
    sout.write(func_a(config, table));
void top
    int const           table[2][1],
    for (int i = 0; i < 2; i++)
        func_b(table[i],sout);
and a testbench:
#include <stdio.h>
void top(const int table[2][1], hls::stream<int>&   sout);
const int table[2][1] = { { 123 }, { 456 } };
int main()
    hls::stream<int>    sout;
    top(table,sout);
        int val = sout.read();
        printf("%d\n", val);
        if (val != table[i][0])
            printf("MISMATCH!\n");
            return -1;
    printf("All Good!\n");
    return 0;
It appears that table index gets passed into the function a couple of clock cycles too late and as a result the function uses old value. I tried passing index along as a separate variable, with the same result.
