Output of hls::CvtColor<HLS_GRAY2RGB> appears gray scale.
I want to use the function hls::CvtColor<HLS_GRAY2RGB>(img_1_g, img_2_rgb) in my code.
This is my image_filter function in top.cpp file:
void image_filter(AXI_STREAM& INPUT_STREAM, AXI_STREAM& OUTPUT_STREAM, int rows, int cols)
//Create AXI streaming interfaces for the core
#pragma HLS INTERFACE axis port=INPUT_STREAM
#pragma HLS INTERFACE axis port=OUTPUT_STREAM
#pragma HLS RESOURCE core=AXI_SLAVE variable=rows metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE core=AXI_SLAVE variable=cols metadata="-bus_bundle CONTROL_BUS"
#pragma HLS RESOURCE core=AXI_SLAVE variable=return metadata="-bus_bundle CONTROL_BUS"
#pragma HLS INTERFACE ap_stable port=rows
#pragma HLS INTERFACE ap_stable port=cols
hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC3> img_1_rgb(rows, cols);
hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC3> img_2_rgb(rows, cols);
GRAY_IMAGE img_1_g(rows, cols);
GRAY_IMAGE img_2_g(rows, cols);
GRAY_IMAGE img_3_g(rows, cols);
#pragma HLS dataflow
hls::AXIvideo2Mat(INPUT_STREAM, img_1_rgb);
hls::CvtColor<HLS_RGB2GRAY>(img_1_rgb, img_1_g);
hls::CvtColor<HLS_GRAY2RGB>(img_1_g, img_2_rgb);
hls::Mat2AXIvideo(img_2_rgb, OUTPUT_STREAM);
where I have typedef of RGB_IMAGE and GRAY_IMAGE in top.h as:
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC3> RGB_IMAGE;
typedef hls::Mat<MAX_HEIGHT, MAX_WIDTH, HLS_8UC1> GRAY_IMAGE;
I don't get any errors during C Synthesis nor C Simulation.
The output of this code seems to be gray scale image. (While viewing the output in IrfanView, the output image is 8 BPP)
It is not converted back to RGB. What would the possible reasons be? Maybe there's something wrong with the way I'm writing the output of hls::CvtColor<HLS_GRAY2RGB> into the output file. However, I have tested other functions like hls::GaussianBlur() and hls::Erode(), they all seem to give proper outputs. The issue is only when the output is supposed to be RGB.
Any suggestions?
Meghana.
Observer maddiott
Re: Output of hls::CvtColor<HLS_GRAY2RGB> appears gray scale.
RGB2GRAY extracts the gray scale information from the three channel image and puts it into a single channel image. The GRAY2RGB simply clones the single channel into each of the three channels of a color image. So not only is a gray image unsurprising, it's the expected behavior.
Observer maddiott
If it clones the single channel into each og the R, G and B channles, I am supposed to get a 24 BPP image when viewed in Irfan View, right? Is there any parameter I have to change while writing my output into a file? Or is there any other way by which I can confirm that it is a 24 BPP image?
I'm guessing you are saving the image in the testbench with imwrite() ?
Try initiating the variable in the test bench as a 3 channel image with Mat::zeros before you save it.
For example:
hls_result = Mat::zeros(imL_hls.rows, imL_hls.cols, CV_8UC3);
AXIvideo2cvMat(axi_dst, hls_result);
imwrite(IMG_OUT_HLS, hls_result);
For me this saves a .bmp image that is 3 times bigger than the image I compare it with which I didn't initiate.
Well, I don't use Mat. This is what I am doing:
IplImage* Final2_Dest;  // outiside main()
Final2_Dest=cvCreateImage(cvGetSize(src2), 8, 3);
AXI_STREAM  Final2_Dest_axi;
image_filter(src2_axi, Final2_Dest_axi,src2->height, src2->width);
AXIvideo2IplImage(Final2_Dest_axi, Final2_Dest);
cvSaveImage(OUTPUT_IMAGE,Final2_Dest);
where OUTPUT_IMAGE has the path defined in top.h as:
#define OUTPUT_IMAGE  "<path>"
When I tried whatever you said, I got this error during C Simulation:
Sorry, the screenshot I had inserted isn't seen in my previous message.
The error is this:
Why are you not using the C++ API for opencv? IplImage is old and deprecated. I suggest using the cv namespace
#include "opencv2/opencv.hpp"
using namespace cv;
 or use cv:: as prefix for functions etc. just like you are doing with hls:: (this also means you could use "using namespace hls;" if you don't want to write hls:: in front of every hls function)
I got an error initially when I used the C++ OpenCV functions. That's why I stuck to this. Anyway, thanks. Now since this problem is fixed, I think I'll try it with C++ APIs.
@meghanadk As the issue is resolved, please close this thread as Solved and mark the post which helped you as an Accepted Solution.
Debraj
