Reading more than one value from a stream
To read single values from a stream, I use:
if(!streamIn.empty())
    x = streamIn.read()
and that is fine. Now I'd like to read pairs of values. I tried:
if(streamIn.size()>1){
    x = streamIn.read();
    y = streamIn.read();
but fails miserably as it's not synthesizable... then I used something like that:
if(!streamIn.empty()){
    if (!streamIn.empty()){
        // ...  pair process...
and that works but for a larger number that will be clumsy... is there a neater way of checking if there are N items in a stream queue?
Scholar u4223374
Re: Reading more than one value from a stream
How about just turning your last version into a loop? That at least is fairly neat.
There's no way to check that a stream contains N elements - the data provided with the stream only tells you whether it contains no elements or at least one element.
My preference is to just read N elements without checking for emptiness first. HLS will automatially wait until the data is available.
Scholar u4223374
I wanted to prevent the function from being blocked waiting for data to come and do something in the meantime, but if there isn't data there is nothing to do as well, so it can be the right thing to do not worry that much.
