Visitor bevan1
Reported function latency off by one
I have found an inconsistency between the reported latency of a function and the actual latency of the generated HDL module. For functions with a latency >1 cycles, the generated HDL takes one cycle more than reported. Following is a simple demonstation:
int add(int x, int y) {
#pragma HLS LATENCY min=N max=N
#pragma HLS INLINE off
#pragma HLS PIPELINE
	return x + y;
int top(int x, int y) {
	return add(x, y);
N is varied between 0 and 3 in the following and we have a look at the HLS report and the generated Verilog for "add".
N=0
  • Report for add: Latency 0, II 1
  • Report for top: Latency 0
  • Verilog module for "add" is purely combinatorial
N=1
  • Report for add: Latency 1, II 1
  • Report for top: Latency 1
  • Verilog module for "add" now contains one output register stage
N=2
  • Report for add: Latency 2, II 1
  • Report for top: Latency 3 (!)
  • Verilog module for "add" now contains two output register stages and additionally buffers the inputs, i.e. it takes three cycles from input to output
N=3
  • Report for add: Latency 3, II 1
  • Report for top: Latency 4
  • Verilog module for "add" adds another output register stage, so it now takes four cycles from input to output
So, the interesting step here is from N=1 to N=2 where two additional register stages are introduced into the HDL code. HLS obviously knows about this and the number of cycles required by "top" increases by two. I tested this with Vivado HLS 2018.1. The generated Verilog code is attached to this post.
Is there a reason for this behavior or is it a bug? I would expect the generated module to take as many cycles as requested using the "HLS LATENCY" pragma and as stated in the HLS report.
Re: Reported function latency off by one
Hello @bevan1,
I am looking into this issue and I will keep  you posted.
Chris
Hello @bevan1,
I have reproduced the issue and I have filed a change request with the developers.
It appears that the PIPELINE directive is adding an additional register on the latency gets above two.  When I removed this directive, the latency matches the expected results.
Good Luck,
Chris
