Should I install i386 library on Ubuntu x86_64?
Dear all,
I tried to use vivado_hls.
When I compile or use csim, vivado_hls occur errors cause by need 32bit library.
Even if my PC installed x86_64 Ubuntu 16.04, should I need to install i386 library?
In my environment, I cannot install i386 lib. easily.
Thank you,
yilee
Re: Should I install i386 library on Ubuntu x86_64?
Hi all,
I used CentOS 7.4 instead Ubuntu 16.04.
Finally there are no issue.
So, I recommend to run in CentOS environment.
yilee
Hi @yilee,
Can you please share the error that you are facing while running Csim?
Hi shameera,
I am sorry that I don't remember error message at compiling and linking in csim.
I just copied some .so files into vivado's dir.
After that, I knew that Ubuntu usually use dash, not bash.
But, SDx SDK think default shell is bash.
So, I change default shell dash to bash.
Finally, I would like run OpenCL data type (ex, int16, ...), but compiler requested to need sys/cdefs.h header file.
But my PC have no /usr/include/sys directory. And I cannot install gcc-multilib package in my office.
Could you understand what is my trouble?
yilee
Hi all,
yilee
