Newbie www_wwwjs1
Simulation passed but synthesis failed
 Hi everybody,
I am trying to implement a 2D correlation function over gray scale image. The algorithm is generally an imitation of the 'hls::filter2D' function in the HLS video library. My implementation has passed the simulation and realized an expected filtered image. However, in the step of synthesis, Vivado HLS reported errors as follows.
I located the mistakes into following loop by a series of modifications and experiments.
for (int bufRow = 0; bufRow < FILTER_HEIGHT; ++bufRow) {
if (row >= PATTERN_AREA_LT_Y && col >= PATTERN_AREA_LT_X && row < PATTERN_AREA_RB_Y &&
col < PATTERN_AREA_RB_X) {
int aCol1 = col - PATTERN_AREA_LT_X;
colBuf(bufRow, 0) = kBuf(bufRow, aCol1);//
Where colBuf and kBuf are LineBuffers just like col_buf and k_buf in hls::filter2D.
for(int buf_row = 0; buf_row < K_HEIGHT; buf_row++) {
// Fetch the column from the line buffer to shift into the window.
assert((x < IMG_WIDTH) && ((BORDERMODE::value == BORDER_CONSTANT::value) || (x >= 0)));
col_buf[k](buf_row,0) = ((BORDERMODE::value == BORDER_CONSTANT::value) && (x < 0)) ? fillvalue : k_buf[k](buf_row,x);
// std::cout << (int)col_buf[k](buf_row,0) << " ";
The project can pass the synthesis by simply calling hls::filter2D, but failed with my own implementation.
Also, I got a succeed version in experiments like,
unsigned char tmp1 = kBuf(bufRow, aCol1);
unsigned char tmp2 = 0;
colBuf(bufRow, 0) = tmp2;//
So, the problem seems come from the relationship between kBuf and colBuf.
Is there any suggestion for this situation?
Thanks in advance. The environment is Vivado HLS version 2014.4.
Re: Simulation passed but synthesis failed
Hi @www_wwwjs1
This could be version specific.
Can you please try using 2016.2?
Thanks,Vijay
