Skipping samples from ap_fifo input: best practices
Apologize for the newbie question.
Let's assume I have the following subfunction (invoked from the top module):
void skip_samples(
    const uint16_t N,
    const uint16_t M,
    int32_t *in,
    volatile int32_t *out
where in is an ap_fifo and out is memory-mapped via a AXI master interface.
The goal is the following:
  • Read N samples from in, and write them contiguously on out
  • Skip M samples from in
  • Read another burst of N samples from in, and append them to out (after the first N)
So, in summary, we need to read N+M+N from in, and write only N+N to out. I understand that out could easily be an ap_fifo as well, but due to the top-level design, it must be AXI-Master memory-mapped.
I seem to have troubles with the "skipping" part. I tried two different design, one based upon for loops, another via memcpy( ), and both hang the board (testbenches work well). On the other hand, interestingly, if I do some sort of explicit processing of the M samples to be skipped (for example, computing a checksum), the module works well. What am I missing?
Re: Skipping samples from ap_fifo input: best practices
My two cents in your question in ap_fifo input :
- If the array is accessed in a sequential manner an  ap_fifo  interface can be used.
- So, I don't see how you skip M samples. Does it break the above rule of FIFO object in HLS ?
Nanson
