UG871 HLS Tutorial error using Vivado HLS 2018.2 and 2018.3
The HLS Turorial C_Validation lab 3 fails to simulate do to compilation errors in 2018.2 and 2018.3.
I have seen these errors in CentOS 7 and Windows 10.
Are there any work arounds?  If this just the case that the tutorial needs to be updated or is this a real HLS bug?
 (The run_hsl.tcl script worked with 2017.4 on the same CentOS 7.6 machine)
Re: UG871 HLS Tutorial error using Vivado HLS 2018.2 and 2018.3
There is an error in the C code.
In file hamming_window_test.cpp remove line 78, or comment it out .
Olivier Trémois
XILINX EMEA DSP Specialist
Olivier Trémois
