Visitor tmrnvrcome
Vivado HLS Compilation Error
I am working with Vivado HLS 2012.4. I have encountered an error during compilation.
@E [HLS-70] llvm-ld: error: Cannot link file '/home/ga54doh/AES_Evaluation/solution1/.autopilot/db/aes.bc': Linking globals named 'Rcon0': symbol multiply defined!
Error in linking the design.
    while executing
"csynth_design"
Can anyone suggest how I may resolve this problem?
Teacher muzaffer
Re: Vivado HLS Compilation Error
Actually my initial conclusion was right. You do have multiple copies of the same symbol. The reason is aes.c includes aes_key.c and you include both .c files in your project. So you get one copy through aes.c and one copy through aes_key.c.
If you remove all .c files except aes.c and change the top function name to aes_main, the project compiles. I am not sure if the result is something useful but there are no errors and rtl is generated. The return is exactly what the aes_main return ie a constant '0' of integer size.
If you need any useful results from this code, I think you would want to make an aes_enc and aes_dec top level functions which take and return parameters. This has nothing to do with HLS but with regular programming. Look at the c code and ask yourself how a client of these interfaces would use them. How does one pass something to aes_enc/dec to process and how does one get the result? When you answer those questions how you need to modify the code will become apparent.
Teacher muzaffer
pay attention to the tool is telling you. Do you have the Rcon0 symbol defined in both files outside any functions? You can have only one declaration of a global symbol; others should be "extern"
Visitor tmrnvrcome
the Rcon0 is defined in the same file. but used in different function. it is like this, in this file aes_key.c, i  have declared and defined this:
const char Rcon0[30] = {
0x01, 0x02, 0x04, 0x08,
0x10, 0x20, 0x40, 0x80,
then in the same file aes_key.c, i have written a function that uses the Rcon0
int KeySchedule (int type, int key[32])
if ((j % nk) == 0)
temp[0] = SubByte (word[1][j - 1]) ^ Rcon0[(j / nk) - 1];
temp[1] = SubByte (word[2][j - 1]);
temp[2] = SubByte (word[3][j - 1]);
temp[3] = SubByte (word[0][j - 1]);
I did not use Rcon0 in other files.
So any suggestions?
Teacher muzaffer
You have a straight link problem. Saying everything is perfect points to a compiler or linker bug. Although it is possible, it is a very low likelihood and it is more likely that there is something wrong with your code. Maybe post your project so that it can be observed in totality ?
Visitor tmrnvrcome
ok.
| CHStone : a suite of benchmark programs for C-based High-Level Synthesis |
#include "aes.h"
//int main_result;
/* **************key generate & key display *******************/
0x1b, 0x36, 0x6c, 0xd8,
0xab, 0x4d, 0x9a, 0x2f,
0x5e, 0xbc, 0x63, 0xc6,
0x97, 0x35, 0x6a, 0xd4,
0xb3, 0x7d, 0xfa, 0xef,
0xc5, 0x91};
/* **************** key expand ************************ */
int
int nk, nb, round_ing;
int i, j, temp[4];
switch (type)
case 128128:
nk = 4;
nb = 4;
round_ing = 10;
break;
case 128192:
nk = 4;
nb = 6;
round_ing = 12;
break;
case 128256:
nk = 4;
nb = 8;
round_ing = 14;
break;
case 192128:
nk = 6;
nb = 4;
round_ing = 12;
break;
case 192192:
nk = 6;
nb = 6;
round_ing = 12;
break;
case 192256:
nk = 6;
nb = 8;
round_ing = 14;
break;
case 256128:
nk = 8;
nb = 4;
round_ing = 14;
break;
case 256192:
nk = 8;
nb = 6;
round_ing = 14;
break;
case 256256:
nk = 8;
nb = 8;
round_ing = 14;
break;
default:
return -1;
} //end of switch..case
for (j = 0; j < nk; ++j)
for (i = 0; i < 4; ++i)
/* 0 word */
word[i][j] = key[i + j * 4];
/* expanded key is generated */
for (j = nk; j < nb * (round_ing + 1); ++j)
/* RotByte */
if ((j % nk) == 0)
if ((j % nk) != 0)
temp[0] = word[0][j - 1];
temp[1] = word[1][j - 1];
temp[2] = word[2][j - 1];
temp[3] = word[3][j - 1];
if (nk > 6 && j % nk == 4)
temp[i] = SubByte (temp[i]);
word[i][j] = word[i][j - nk] ^ temp[i];
return 0;
Teacher muzaffer
What is the source of the aes.bc bit code file? That's where the complaint is coming from.
Visitor tmrnvrcome
Here it is. As attached.
Visitor tmrnvrcome
Sorry, but i am new to using Vivado HLS. How do I open the .bc file in Vivado HLS? Or is there any way that I can open it? I am using Windows 7 OS.
Teacher muzaffer
I downloaded and looked at the CHStone\aes project. This project doesn't seem to be structured for HLS as far as I can tell. aes.c seems to be a something like a testbench but it includes all the other C files and aes_enc writes its output to a global variable. As far as I understand HLS, these files need some work to be useful for it.
I think aes_enc and aes_dec should be work on so that they can get inputs and outputs as parameters and return results.
Could you attach the entire project with all source files?
Cheers,
Jim
Visitor tmrnvrcome
ok. I have attached the enitre project. Please give me some advice and help me out, I am not sure how to move on from this error.
Visitor tmrnvrcome
so it means i have to modify the codes?
Sorry, I am new to HLS.
Teacher muzaffer
Visitor tmrnvrcome
And how do I make aes_enc and aes_dec as top level functions?
Visitor tmrnvrcome
When you say remove all .c files, do you mean removing from the 'Sources' tab, or do you mean to exclude the lines in the aes.c:
#include "aes_enc.c"
//#include "aes_dec.c"
//#include "aes_key.c"
//include "aes_func.c"
Only one function can be set as top function for RTL synthsis.
To do it,  open Project->Project Settings->Synthesis, and then set "aes_enc" for top function.
brucey
Some guidelines for c coding:
1. Do not include source file(*.c) in another source file.
2. Add macro check for head file(*.h). For example,
add following two line to the start of your "aes.h"
    #ifndef __AES_H__
    #define __AES_H__
 add following line to the end of your "aes.h"
    #endif
brucey
