Visitor ra_amine
Vivado HLS, Impossible to add new solution
Hello everyone,
I am trying to follow the Vivado HLS tutorial (UG871) that consist in the design of an FIR filter.
in page 36, I need to create a new solution to compare it with the previous one but I can't. if I click on the New Solution button nothing happens and if I try to do it again I get a message saying the solution already exits (ie: the folder and files are created but are not visible in the project explorer).
I am using the 30days evaluation license.
Is this problem because of the 30 days license or something else?
Thank you.
Re: Vivado HLS, Impossible to add new solution
This is a known issue in Vivado-HLS 2012.4.
Refer to article http://www.xilinx.com/support/answers/53649.htm to workaround this.
This is also fixed in the ISE 14.4 product update available at http://www.xilinx.com/support/download/index.htm
Deepika.
Deepika.
Deepika.
Deepika.
Visitor ra_amine
Hello Vemuald,
The update did not fix the problem for me. However, the reselection of the device when creating a new solution worked fine.
Thank you for your help.
