Visitor mehmettukel
Vivado HLS SystemC HDL Co-Simulation (without synthesizing)
Hi there,
I know it is possible with Vivado HLS to synthesize SystemC code into HDL and simulate it. How about simulating a VHDL module which I have written earlier with a SystemC testbench? Again, HDL module is not synthesized from SystemC code. Is it possible to do that?
Mehmet
Re: Vivado HLS SystemC HDL Co-Simulation (without synthesizing)
The short answer is that its not possible. You cannot add RTL files directly to HLS for co-simulation. The entry point would be to add C/C++/SystemC file in HLS.
Debraj
Debraj
Visitor mehmettukel
Thank you debrajr. But isn't it nice if Vivado HLS can do that. Maybe Xilinx can consider this in next releases.
How to synthesis or creating a project  using  systemc program into HDL using Vivado? Can you please share any document if you have?
