Visitor ank59
Vivado HLS Video Libraries - HoughLines2 - Unable to synthesize
We are trying to implement a straight line plotting algorithm based on the parameterterized outputs received from a Hough Line Transform block. We are using the hls::houghlines2 library for applying the Hough Transform to a pre-processed single channel image. The design passes the C simulation. However, the issue is we are not able to synthesize the design and we keep seeing warnings like this:
Completely partitioning array 'lines_val.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'lines_flag.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'addr.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'sinval.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'cosval.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
Completely partitioning array 'accbuf.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array '_accum.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'lines.angle.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
@W [XFORM-104] Completely partitioning array 'lines.rho.V' accessed through non-constant indices on dimension 1, which may result in long runtime and suboptimal QoR due to large multiplexers. Please consider wrapping the array access into a function or using a register file core instead.
The synthesis process hangs after this! Not sure if this is due to a design issue in the HLS library or are we missing something somewhere..
I have attached the codes. Any suggestions on fixing this would be helpful.
Visitor ank59
Re: Vivado HLS Video Libraries - HoughLines2 - Unable to synthesize
Attaching the synthesis log
Which Vivado version is this and what OS are you using?
Debraj
Newbie yang0907
Hi, we met the same problem in Vivado 2013.3, is there any suggestions?
