Visitor donert
Vivado HLS not run, Black Command Screen seen
After the installation, I runned the Vivado HLS but show an error : libSecurity.dll does not exist on your computer.
I copied 'libSecurity.dll'  to C:XLINX/vivado_HLS/2013.2/bin and then it is solved.
But now, I click the Vivado HLS and then a black command screen is seen for a moment.So it is not open.
Thank you much,
Tugay
Re: Vivado HLS not run, Black Command Screen seen
Looks like a issue with installation and corruption of files.
Can you try reinstallation and check if it resolves the issue.
Satish
Hi.
Please also try the suggestions from below related post
http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Vivado-HLS-does-Not-run-Black-Command-Screen-is-seen/td-p/369501
Vanitha.
1. The libSecurity.dll and libSecurity_FNP.dll both are required. Try copying both the .dll from an older working install.
2. Vivado HLS is a 32-bit application. The 32-bit service should also be installed on that machine.
3. 32-bit service can be installed through following command
installanchorservice.exe xilinxd Xilinx-Software.
This utility is available under Vivado\2013.2\bin\unwrapped\win32.o.
This requires administrative privileges.
Debraj
