Vivado HLS
How to create a test bench for a cpp programme in vivado HLS.Please help me with this.
Scholar u4223374
Re: Vivado HLS
In the "Explorer" pane on the left-hand side, right-click on "Test Bench" and then select "New File...". Name the file, create a main function that does what you want, and you're finished.
Re: Vivado HLS
Thanks for the response sir.
But I need to know how to use the function in the testbench.If there is any syntax for that,please help me with the solution.
Scholar u4223374
Re: Vivado HLS
The syntax is very simple:
int main() {
// your code goes here.
return 0;
In the "your code goes here" section, you need to generate or read some test data suitable for your application, turn that into a form suitable for the module you're testing, run that module with the data, collect results, and compare the results to known-good data. Until you actually post the code that you're trying to test, it's going to be pretty difficult to give more information.
Scholar dpaul24
Re: Vivado HLS
krishnendu@123,
you should read the tutorials first.A very basic one - https://www.so-logic.net/documents/upload/Basic_HLS_Tutorial.pdf
There are many others, from Xilinx as well as other Youtube vdos.
FPGA enthusiast!
All PMs will be ignored
Re: Vivado HLS
Thanks for the reply sir,i will send you the code
#include <stdio.h>
#include <ctime>
#include <stdlib.h>
#include "haar.h"
#include "image.h"
using namespace std;
int main ( int argc, char *argv[] )
int flag;
int in_flag , in_width , in_height , in_maxgrey;
int ret_val=1;
printf ("-- entering main function --\r\n");
printf ("-- loading image --\r\n");
// 320 X 240 Input image in hex format
#include INPUT_IMAGE
double duration;
// Arguments to be passed to DUT
MyRect result[RESULT_SIZE];
int result_x[RESULT_SIZE];
int result_y[RESULT_SIZE];
int result_w[RESULT_SIZE];
int result_h[RESULT_SIZE];
int res_size=0;
int *result_size = &res_size;
int i;
// As the SDSoC generated data motion network does not support sending 320 X 240 images at once
// We needed to send all the 240 rows using 240 iterations. The last invokation of detectFaces() does the actual face detection
for ( i = 0; i < IMAGE_HEIGHT-1; i+=1 ){
detectFaces ( Data[i], result_x, result_y, result_w, result_h, result_size);
printf ("-- detecting faces --\r\n");
std::clock_t start = std::clock();
detectFaces ( Data[IMAGE_HEIGHT-1], result_x, result_y, result_w, result_h, result_size);
duration = ( std::clock() - start ) / (double) CLOCKS_PER_SEC;
printf("\nresult_size = %d", *result_size);
for (int j = 0; j < RESULT_SIZE; j++){
result[j].x = result_x[j];
result[j].y = result_y[j];
result[j].width = result_w[j];
result[j].height = result_h[j];
for( int i=0 ; i < *result_size ; i++ )
printf("\n [Test Bench (main) ] detected rects: %d %d %d %d",result[i].x,result[i].y,result[i].width,result[i].height);
if ( *result_size > 0 ) ret_val = 0;
printf("\n-- saving output image [Start] --\r\n");
// Draw the rectangles onto the images and save the outputs.
for(i = 0; i < *result_size ; i++ )
MyRect r = result[i];
drawRectangle(Data, r);
flag = writePgm((char *)(OUTPUT_FILENAME),Data);
printf("\n-- saving output image [Done] --\r\n");
printf("DURATION: %2f", duration);
return ret_val;
Re: Vivado HLS
Thanks for the reply sir.
