Visitor mgoubert
Vivado HSL C simulation error
I'm working in ubuntu 12.04 lts,
and i have the following problem:
Starting C Simulation ...
/opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/vivado_hls_bin -flow csim -flow_args " -setup"
@I [LIC-101] Checked out feature [HLS]
@I [HLS-10] Running '/opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/vivado_hls_bin'
@I [HLS-10] On platform 'Linux_x86_64 version 3.2.0-32-generic'
@I [HLS-10] Vivado HLS Tcl shell started on Sat Nov 03 16:55:35 CET 2012 for user 'root' at host 'matthias-MacBookPro'
@I [HLS-10] Current directory: /home/matthias/Documents/zynq/labsolution/lab1/matrixmul.prj/solution1
   Generating csim.exe
/usr/bin/ld: /opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/libstdc++.so.6: version `GLIBCXX_3.4.10' not found (required by /usr/bin/ld)
/usr/bin/ld: /opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/bin/ld)
/usr/bin/ld: /opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required by /usr/bin/ld)
collect2: ld returned 1 exit status
make: *** [csim.exe] Error 1
@E [SIM-33] Error(s) found in compilation.
@E [SIM-1] CSim file generation failed with errors.
@I [LIC-101] Checked in feature [HLS]
 I tried to link it, replace it. But then the program won't start. I had some problems with header files, but those i fixed by installing them. This however i can't get fixed. Can someone help me? Or does someone have te same problem?
Thnx
Thx
Visitor mgoubert
Re: Vivado HSL C simulation error
Found it myself:
ln -sf /lib/x86_64-linux-gnu/libsrdc++.so.6 /opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/libsrdc++.so.6
ln -sf /lib/x86_64-linux-gnu/libgcc_s.so.1 /opt/Xilinx2/Vivado_HLS/2012.3/Linux_x86_64/bin/libgcc_s.so.1
sudo ln -s /usr/lib/x86_64-linux-gnu /usr/lib64
Then alle the problems where gone!
Ty
Newbie nattha.s
Re: Vivado HLS C simulation error..
Please help me. Silimlar problem
Invalid attribute value ' –DHW_COSIM'
    while executing
"add_files -tb matrixmul1_test.cpp -cflags "–DHW_COSIM""
    (file "D:/Xilinx_project/HLS/labs/lab1/matrixmul.prj/solution1/script.tcl" line 9)
hi
could you please attached the script.tcl file.
so that i can check that tcl script.
regards,
ankur
Visitor enghanaa
I face similar problem under ubuntu 12.04
@E [SIM-1] 'csim_design' failed: compilation error(s).
4
while executing
"csim_design -quiet"
(file "... workspace/sobel/sobel_prj/solution1/csim.tcl" line 8)
Please tell me how you get those sympolic links as i didnt find them
Thank you
Hanaa
Please check the supported OS list for Xilinx tools. If you are using any OS which is not listed like Ubuntu etc then we cannot guarantee the tool performance.
Debraj
Visitor metzli_12
I have a similar problem when I run the example XAPP1231 - Partial Reconfiguration of a Hardware Accelerator with Vivado Design Suite, I am using ubuntu 14.04 (which is supported by xilinx tools) and vivado_hls 2015.3, any  solution?
Do you have tried ?
This just works on my side.
Ahh, just see the following after editing the CFLAGS:
The first time I get an error (seems that it doesnt clear all content even if I say "Clean build")
Starting C simulation ...
C:/Xilinx/Vivado_HLS/2015.4/bin/vivado_hls.bat D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4/AFAProcessing_64Bit_250MHz/csim.tcl
@I [HLS-10] Running 'C:/Xilinx/Vivado_HLS/2015.4/bin/unwrapped/win64.o/vivado_hls.exe'
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:49:12 +0100 2016
            in directory 'D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha'
@I [HLS-10] Opening project 'D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4'.
@I [HLS-10] Opening solution 'D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4/AFAProcessing_64Bit_250MHz'.
@I [SYN-201] Setting up clock 'default' with a period of 2.5ns.
@I [HLS-10] Setting target device to 'xc7vx690tffg1761-2'
@E [SIM-1] CSim failed with errors.
4
    while executing
"source D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4/AFAProcessing_64Bit_250MHz/csim.tcl"
    invoked from within
"hls::main D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4/AFAProcessing_64Bit_250MHz/csim.tcl"
    ("uplevel" body line 1)
    invoked from within
"uplevel 1 hls::main {*}$args"
    (procedure "hls_proc" line 5)
    invoked from within
"hls_proc $argv"
The second time - without any modification goes through:
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:13 +0100 2016
   Compiling(apcc) ../../../../src/main.c in debug mode
@I [HLS-10] Running 'c:/Xilinx/Vivado_HLS/2015.4/bin/unwrapped/win64.o/apcc.exe'
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:16 +0100 2016
            in directory 'D:/Projects/AFA/git/src/fpgaPlayground/HLS/AFAalpha/AFAHls2015.4/AFAProcessing_64Bit_250MHz/csim/build'
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/14923969998321
@I [APCC-1] APCC is done.
   Compiling(apcc) ../../../../src/AFASpectra.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:19 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/85043973066610
   Compiling(apcc) ../../../../src/AFARandom.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:22 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/74123976152723
   Compiling(apcc) ../../../../src/AFAProcessing.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:25 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/43643979096492
   Compiling(apcc) ../../../../src/AFANetworkSettings.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:28 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/91923982405870
   Compiling(apcc) ../../../../src/AFASpectraHW.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:31 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/111643985108990
   Compiling(apcc) ../../../../src/AFARandomHW.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:34 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/74363987912230
   Compiling(apcc) ../../../../src/AFAProcessingHW.c in debug mode
            for user 'uidr7560' on host 'bhd4wf4g' (Windows NT_amd64 version 6.1) on Thu Mar 17 14:51:37 +0100 2016
@I [APCC-3] Tmp directory is D:/tmp/apcc_db_uidr7560/49323990881265
   Generating csim.exe
My .tcl script looks like this:
## This file is generated automatically by Vivado HLS.
## Please DO NOT edit it.
## Copyright (C) 2015 Xilinx Inc. All rights reserved.
open_project AFAHls2015.4
set_top AFAProcess_HW
add_files src/AFATypes.h
add_files src/AFASpectraHW.h
add_files src/AFASpectraHW.c
add_files src/AFARandomHW.h
add_files src/AFARandomHW.c
add_files src/AFAProcessingHW.h
add_files src/AFAProcessingHW.c
add_files src/AFANetworkSettingsHW.h
add_files src/AFADefines.h
add_files -tb src/main.c -cflags "-DHW_COSIM"
add_files -tb src/AFATypes.h
add_files -tb src/AFASpectraCommon.h
add_files -tb src/AFASpectra.h
add_files -tb src/AFASpectra.c
add_files -tb src/AFARandomCommon.h
add_files -tb src/AFARandom.h
add_files -tb src/AFARandom.c
add_files -tb src/AFAProcessingCommon.h
add_files -tb src/AFAProcessing.h
add_files -tb src/AFAProcessing.c
add_files -tb src/AFANetworkSettingsCommon.h
add_files -tb src/AFANetworkSettings.h
add_files -tb src/AFANetworkSettings.c
add_files -tb src/AFADefines.h
open_solution "AFAProcessing_64Bit_250MHz"
set_part {xc7vx690tffg1761-2}
create_clock -period 2.5ns -name default
config_interface -m_axi_addr64 -m_axi_offset off -register_io off
csim_design -clean
Newbie surajitmal
Currently I'm using Vivado HLS 2016.4 tool. Facing "CSim failed with errors" when classes or class member functions are set as the top-level for synthesis.
[Note: not good to push up old posts, you should open a new one as this is a different issue I think]
You can't set a class as top-level. It must be a static function, see UG902 or even
https://www.xilinx.com/support/answers/54135.html
