Observer umair0722
Vivado hls tool not updating the changes in header file
I am new to vivado hls, I am using vivdo 2013.1. I started with a basic example from ug902 pg109-110 section "AXI4 Master Interface". here it is
#include "ap_cint.h"
#include "example.h"
void example (volatile DT *m) {
	// Define the RTL interfaces
	#pragma HLS interface ap_ctrl_none port=return
	#pragma HLS interface ap_bus port=m
	// Define the pcore interface as an AXI4 master
	#pragma HLS resource core=AXI4M variable=m
	DT buff[N], tmp;
	int i, j;
	memcpy(buff, m, N * sizeof(DT));
	for (i = 0, j = N - 1; i < j; i++, j--) {
		tmp = buff[i];
		buff[i] = buff[j];
		buff[j] = tmp;
	memcpy(m, buff, N * sizeof(DT));
/* example_test.c
int main () {
    DT temp[N];
    int i;
    FILE *fp;
    for (i = 0; i < N ; i++ )
        temp[i] = i;
    // Execute the function
    example(temp);
    fp=fopen("out.dat","w");
        fprintf(fp, "%i : %d\n", i, temp[i]);
        printf("%i : %d\n", i, temp[i]);
    fclose(fp);
    return 0;
The value of N is defined in example.h file which resides in the same directory as this src file. I wrote a simple c code for testing the above function, it fills an array, calls this function and prints the result. Till now everything works fine and i get the desired result.
But when I change the value of N in example.h  it is not updated when i see the result. Interestingly when i hover over N the MACRO EXPANSION shows the new value.
(Project Settings > General > "Parse All Header" Files option is checked)
Can you tell why is the value of N from header file is not updated and how should it be done?
Umair
Re: Vivado hls tool not updating the changes in header file
Hello Umair,
I think the answer goes along this line..:
I think you're talking about the C-simulation and in this situation the VHLS tool is based on makefiles.
The inputs files for the dependancies are the ones setup in the project - usually that's only the C files, not the header files.
If you modify the header file that changes N, then the c-sim will not see it as the dependancies do not include the header file.
Solutions (solution 1 should be more effiecient):
1- include the header file to your project - notice you will get a warning from the tools but you can ignore it.
2- you can also use the check box option "clean" in the setting window when you start the c-simulation, this doesn't have the same effect but should still qualily work.
I hope this helps.
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Observer umair0722
Thanks Herve for the reply. Solution 1 did not work for me. The tool did not even gave warning when I added .h file to the sources. Solution 2 did work.
One more thing moving forward. I am exporting an example (your toy example here) design as pcore. I wanted to ask which driver files should be used with this pcore as there are two options
1- solution1/impl/drivers/example_v1_00_a/src ; here are 5 files (i need four of them for standalone development)
2- solution1/impl/pcores/example_v1_00_a/include ; 3 files here
I have integrated this example pcore with my PS using XPS and exported the HW design in SDK.Now, if i am using option 1 I cannot find some required variables eg XPAR_XEXAMPLE_NUM_INSTANCES, XExample_ConfigTable and xx_DEVICE_ID.
Ideally they should be present in xparameters.h ?
can you suggest why they are not generated or how should they be generated/created?
thanks
