ap_memory interface scheduling error
[ Edited ]
EDIT: added a simple code example.
I have a piece of code that is pipelined with II=3, and performs up to 3 accesses to a BRAM array:
#include <ap_int.h>
#include <hls_stream.h>
#define LENGTH 20
typedef ap_uint<LENGTH * 8> element;
typedef element memory[1 << 18];
size_t h(const element& tag) {
#pragma HLS inline off
#pragma HLS pipeline enable_flush ii=3
    std::size_t seed = 5381;
    for (int i = 0; i < LENGTH; ++i) {
#pragma HLS unroll
        seed = ((seed << 5) + seed) + tag(i * 8 + 7, i * 8);
    return seed;
void top(hls::stream<element>& write_stream, const element& aread,
         hls::stream<bool> bool_stream, element *read, const element& awrite, memory m) {
#pragma HLS interface ap_memory port=m
#pragma HLS resource core=RAM_1P variable=m latency=1
    if (write_stream.empty()) {
        m[h(awrite)] = write_stream.read();
    if (bool_stream.empty())
        return;
    if (bool_stream.read())
        *read = m[h(aread)];
    else
        if (m[h(awrite)] == 1)
            m[h(awrite)] = 0;
Instead of II=3, I'm getting II=4 for the top function, and these errors:
WARNING: [SCHED 204-63] Unable to schedule the whole 2 cycles 'store' operation (top.cpp:27) of variable 'tmp.V', top.cpp:27 on array 'm_V' within the first 3 cycles (II = 3).
WARNING: [SCHED 204-63] Please consider increasing the target initiation interval of the pipeline.
WARNING: [SCHED 204-69] Unable to schedule 'load' operation ('m_V_load_1', top.cpp:36) on array 'm_V' due to limited memory ports.
WARNING: [SCHED 204-63] Unable to schedule the whole 2 cycles 'store' operation (top.cpp:27) of variable 'tmp.V', top.cpp:27 on array 'm_V' within the first 4 cycles (II = 4).
Remove the calls to the hash function h(), or decreasing the LENGTH macro to 1 byte eliminates the warnings.
Any idea what can cause this kind of behavior?
Re: ap_memory interface scheduling error
You're going to have to show us some example code that demonstrates this behavior before anyone can assist.
Thanks. I tried creating a minimal example that I can post, but the error didn't show there. Anyway, I'll continue try to create an example.
@jprice, I was finally able to create a minimal example. I've updated the post with it. Could you have a look?
Haggai
