Visitor sirainatou
error c simulation filter2D
Hello everyone ,
I am trying to Applies an arbitrary linear filter to an image src "numIteration" time !
I tried this code !
SHORT_IMAGE u(rows,cols)
Zero(u);
#pragma HLS INLINE
SHORT_IMAGE internal[numIteration-1];
#pragma HLS array partition variable=internal dim=1
computeDerivatives1(u,internal[0],average);
/*loop:for(int k=0; k<numIteration; k++){
computeDerivatives1(internal[k],internal[k+1],average);
with :
template<int ROWS, int COLS, int SRC_T, int DST_T>
void computeDerivatives1(
Mat<ROWS,COLS,SRC_T>& src,
Mat<ROWS,COLS,DST_T>& dst,
const int tab[3][3]){
hls::Window<3,3,int> kernel;
hls::Point_<int> anchor;
for (int i = 0; i <3; i++)
for (int j = 0; j < 3; j++)
kernel.val[i][j] = tab[i][j];
anchor.x = -1;
anchor.y = -1;
hls::Filter2D(src, dst, kernel, anchor);
but i got the error : WARNING: Hls::stream 'hls::stream<float>.21' contains leftover data, which may result in RTL simulation hanging.
Any idea please !!
Re: error c simulation filter2D
check these links
http://www.xilinx.com/support/answers/57876.html
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/HLS-Compiler-Bug-Streaming-Based-Design/td-p/349833
Thanks and Regards
Balkrishan
Visitor sirainatou
the data read while emplty is "internal[0]" !! but I didn't understand why I got this warning despite the fact that I applied the filter !!
in fact, my goal is to apply the filter several times on the same image !!
thanks for your response
Scholar u4223374
Can you post the definitions you're using (eg. what is "SHORT_IMAGE")? And also the complete code, since the first function is clearly incomplete?
In this code
Zero(u);
#pragma HLS INLINE
(the rest seems to be commented out) is there something that reads internal[0]? And does it read all of internal[0]?
In the code that is commented out, each iteration writes to internal[k+1]. Maximum value for k is (numIteration-1) so the maximum image written to is internal[numIteration]. This will obviously cause problems, because you've defined internal has having numIteration-1 elements. It needs numIteration+1 elements.
Visitor sirainatou
Thanks for your help !
I posted here the whole code . honestly, I do not know what the instruction internal [numIteration] means ! I influenced the source code of the function:
template<typename OPR_KERNEL, typename BORDERMODE, int ITERATIONS,int SRC_T, int DST_T, typename KN_T, typename POINT_T,
int IMG_HEIGHT,int IMG_WIDTH,int K_HEIGHT,int K_WIDTH>
void filter_opr_iter(
Mat<IMG_HEIGHT, IMG_WIDTH, SRC_T> &_src,
Mat<IMG_HEIGHT, IMG_WIDTH, DST_T> &_dst,
Window<K_HEIGHT,K_WIDTH,KN_T> &_kernel,
Point_<POINT_T> &anchor,
int rows,int cols )
#pragma HLS INLINE
Mat<IMG_HEIGHT,IMG_WIDTH,DST_T> internal[ITERATIONS-1];
filter_opr_flow_more<OPR_KERNEL,BORDERMODE,SRC_T,DST_T,KN_T,POINT_T>(_src,internal[0],_kernel,anchor,rows,cols);
loop_iterations: for(int iter=0;iter<ITERATIONS-2;iter++)
#pragma HLS UNROLL
filter_opr_flow_more<OPR_KERNEL,BORDERMODE,SRC_T,DST_T,KN_T,POINT_T>(internal[iter],internal[iter+1],_kernel,anchor,rows, cols);
filter_opr_flow_more<OPR_KERNEL,BORDERMODE,SRC_T,DST_T,KN_T,POINT_T>(internal[ITERATIONS-2],_dst,_kernel,anchor,rows,cols);
As I said ! I want to apply the same filter many times on the same image!!
thank you for your help !
Scholar u4223374
Okay, now I'm really confused. Two major issues I can see in that code:
(1) The initial input to the computeDerivatives1 processing ("u") is initialized to zero. Filtering a blank image is going to give you a blank image, no matter what filter you use. Since the output from this feeds into the subsequent calls to computeDerivatives1, all of those will output zeros too.
(2) It does not look like you ever use the output from the filter loop. Where is the output image meant to go?
(3) Ix_m gets used twice. This is OK in C, but will not work in HLS (you can only use each Mat once).
Visitor sirainatou
my code is not finished yet! I am trying to understand the interest of such a statement!
in my application,
u will be changed in each iteration! That's why I changed the u with a non-empty picture !
and I am ok with your third remark !!
