Visitor anbaz
exporting a Vivado HLS design to ISE
I'm using Vivado HLx 2018.2. I know it does n't support earlier 6 series devices.
My question is regarding use of Vivado HLS Software (2018.2) :
I had seen users target Spartan6 series devices etc with ealier versions of Vivado HLS but I could not find any support for targeting these devices with current version tool.
I want to export a Vivado HLS design to a Spartan6 device for use with ISE 14.7.
I have a valid VIVADO_HLS (and HLS) license but could n't find any options to export the design to ISE or target a Spartan6 device.
Also, the Pcore export option does not show in the export panel.
Any suggestions?
Thanks!
Scholar u4223374
Re: exporting a Vivado HLS design to ISE
As far as I can tell, you can use HLS 2015.4 (and only 2015.4) to produce code for the ISE-specific devices.
2015.3 and earlier required a special license; HLS wasn't supported on the WebPack license, and the ISE devices needed an additional license.
Everything from 2016.1 onwards dropped support for the ISE-specific devices.
In between you have 2015.4 - the first version to be included on the free WebPack license, and the last version to support ISE-specific devices.
Scholar drjohnsmith
can you export a RTL design ?
Visitor anbaz
I could only export RTL as IP into Vivado from Vivado HLS.
None into ISE or target any Spartan6 device from Vivado HLS.
Scholar u4223374
That's correct, with a valid Vivado license, Vivado HLS 2015.4 allows you to target ISE devices.
Visitor anbaz
Thanks all for pointing to the correct version which supports these devices..
