fixed point type casting for SystemC and C++
Here I find one issue.
It's like that when I multiply two COMPLEX fixed point numbers, I need to cast the complex multiplicant and multiplicator. But for REAL fixed point numbers, it seems I donnot have to do type casting before multiplication. I have a small example below.
typedef ap_fixed<4,3> data_in_t;
typedef ap_fixed<8,6> data_out_t;
void fixtest(data_in_t in1,data_in_t in2, data_out_t *out) {
 *out = in1 * in2;
int main () {
    data_in_t in1 = 3.5;
    data_in_t in2 = 3.5;
    data_out_t out;
    fixtest( in1, in2, &out);
    cout << out << endl;
    return 0;
out = 12.25. ( correct, without typecasting )
is there anyone who has such experience before?
and for complex fixed point number, if I have to do type casting befor multiply, it will consumes more resources, which is not I expected. How can I avoid this?
For example:
typedef ap_fixed<25,3> in_t;
typedef ap_ufixed<16,8> out_t;
typedef complex<ap_fixed<25,3> > data_in_t;
typedef ap_fixed<50,6> cast_t;
out_t tmp;
tmp = real(complex<cast_t >(in_value) * complex<cast_t >(conj(in_value)));
and in another environment (from Synopsys), type casting for multiplication is even not necessary for SystemC complex fixed data type (sc_fixed), which seems not the same for complex ap_fixed in C++.
Jim
Teacher muzaffer
Re: fixed point type casting for SystemC and C++
@jianmingli1 can you show what happens if you just do:
complex<ap_fixed<10, 5> > a, b, c;
c = a * b;
Teacher muzaffer
@jianmingli1 tried the following code and it works as expected (you can try to comment out real/imag lines and see with initializations)
#include <ap_fixed.h>
#include <complex>
int main(void) {
        std::complex<ap_fixed<15, 5> > a(2, 0);
        std::complex<ap_fixed<15, 5> > b(4, 0);
        std::complex<ap_fixed<15, 5> > c;
        a.real(0);
        a.imag(1);
        b.real(0);
        b.imag(1);
        c = a * b;
        std::cout << "a:" << a << " b:" << b << " c: " << c;
@muzaffer
Hi friend,
thanks for the feedback.
I see you set both input and output data type as complex<ap_fixed<15,5> >, and the test data with a small value. Could you try with a big value, which makes the multiplication with a possible overflow, like a(10, 1), b(12, 2), then the output should be set with a different word and integer length. And I think without typecasting this will not work as expected.
std::complex<ap_fixed<15, 5> > a(2, 0); std::complex<ap_fixed<15, 5> > b(4, 0); std::complex<ap_fixed<15, 5> > c;
