fixed point type casting issue
Here I find one issue.
It's like that when I multiply two COMPLEX fixed point numbers, I need to cast the complex multiplicant and multiplicator. But for REAL fixed point numbers, it seems I donnot have to do type casting before multiplication. I have a small example below.
fixed point example:
typedef ap_fixed<4,3> data_in_t;
typedef ap_fixed<8,6> data_out_t;
void fixtest(data_in_t in1,data_in_t in2, data_out_t *out) {
 *out = in1 * in2;
int main () {
    data_in_t in1 = 3.5;
    data_in_t in2 = 3.5;
    data_out_t out;
    fixtest( in1, in2, &out);
    cout << out << endl;
    return 0;
out = 12.25. ( correct, without typecasting )
complex fixed point example:
typedef complex<ap_fixed<4,3> > data_in_t;
typedef complex<ap_fixed<8,6> > data_out_t;
data_in_t in1 = data_in_t(1,3);
data_in_t in2 = data_in_t(2,3);
data_out_t out;
Out = in1 * in2;
-> Out = (1,1) (wrong, without typecasting)
Out =data_out_t( in1) * data_out_t(in2);
-> Out = (-7,9) (correct, with typecasting)
is there anyone who has such experience before?
and for complex fixed point number, if I have to do type casting befor multiply, it will consumes more resources, which is not I expected. How can I avoid this?
For example:
typedef ap_fixed<25,3> in_t;
typedef ap_ufixed<16,8> out_t;
typedef complex<ap_fixed<25,3> > data_in_t;
typedef ap_fixed<50,6> cast_t;
out_t tmp;
tmp = real(complex<cast_t >(in_value) * complex<cast_t >(conj(in_value)));
and in another environment (from Synopsys), type casting for multiplication is even not necessary for SystemC complex fixed data type (sc_fixed), which seems not the same for complex ap_fixed in C++.
In SystemC with sc_fixed:
typedef complex<sc_fixed<4,3> > data_in_t;
typedef complex<sc_fixed<8,6> > data_out_t;
data_out_t out;
Out = in1 * in2;
-> Out = (-7,9) (right, without typecasting)
Jim
Teacher muzaffer
Re: fixed point type casting issue
@jianmingli1 It's possible there is a bug in interaction of complex and ap_fixed for Xilinx. Maybe the traits which are generating the output type don't work for templated types.
@muzaffer yes, I think for complex fixed point explicit type CONVERSION is not supported for Xilinx yet.
@jianmingli1
CR has been filed for factory to look into this issue.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the 'thumbs-up' button).
@nupurs
Hi, friend,
What does CR stand for here?
Teacher muzaffer
@jianmingli1 Change Request. I opened an SR with the test case I made and now there is a CR to fix it.
@nupurs
that is great. Thanks a lot.
Best regards
@jianmingli1
CR stands for Change Request and through CR we intimate the factory that there is a bug in the tool that needs to be fixed.
Nupur
