Observer a_mansouri
libtiff.so.3, undefined reference to `TIFFReadEncodedStrip'
i am using vivado hls to snthetise opencv funvtion, i get this error, can you help me please !!!!!!!
I [HLS-10] Setting target device to 'xc7z020clg484-1'
   Generating csim.exe
/usr/bin/ld: warning: libtiff.so.3, needed by /opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so, not found (try using -rpath or -rpath-link)
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFReadEncodedStrip'
/opt/Xilinx/Vivado_HLS/2 014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFReadEncodedTile'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFGetField'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFReadRGBATile'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFScanlineSize'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFSetField'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFSetWarningHandler'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFIsTiled'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFWriteScanline'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFRGBAImageOK'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFOpen'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFReadRGBAStrip'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFSetErrorHandler'
/opt/Xilinx/Vivado_HLS/2014.1/lnx64/tools/opencv/libopencv_highgui.so: undefined reference to `TIFFClose'
collect2: ld returned 1 exit status
make: *** [csim.exe] Erreur 1
@E [SIM-1] 'csim_design' failed: compilation error(s).
4
    while executing
"csim_design -quiet"
    (file "/home/mansouri/hls_project/harris/solution1/csim.tcl" line 8)
@I [LIC-101] Checked in feature [HLS]
regards
Observer a_mansouri
Re: libtiff.so.3, undefined reference to `TIFFReadEncodedStrip'
SOLUTION:
Getting libtiff.so.3 just download tiff-3.9.7.zip from here, unzip it, cd into tiff-3.9.7, then do './configure; make' then cp libtiff/.libs/libtiff.so.3* to /usr/lib64, run ldconfig .
REGARDS,
this is probably an OS or setup issues.
you should try to install the missing lib using your OS utilities.
what OS are you using?
remember that ubuntu, for example isn't supported by Xilinx tools, but with ubuntu you would do:
sudo apt-get install libtiff3
(or libtiff4 etc)
what does ``find /usr/lib* | grep tiff`` returns?
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
Observer a_mansouri
i installed libtiff4
it seems i must link or add the options of cosimulation but i don't now how
that what retrun the commande find
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_12.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_14bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/.cvsignore
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_08bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_08.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/read.t
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_14.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_08_tiled32x32.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/write.t
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_16.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_08_planar.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_12bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_16.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_16bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_32bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_256.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_16_matte.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_256_planar_separate.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_04bit_matte.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_04bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_08_stripped.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_01bit_minwhite.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_08_matte.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_10.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_01bit_minwhite.cals
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_08bit_matte.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_truecolor_32.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_256_matte.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_gray_10bit.tiff
/usr/lib/GraphicsMagick-1.3.9/PerlMagick/t/tiff/input_palette_256_planar_contig.tiff
/usr/lib/GraphicsMagick-1.3.9/coders/tiff.c
/usr/lib/GraphicsMagick-1.3.9/coders/.deps/magick_libGraphicsMagick_la-tiff.Plo
/usr/lib/GraphicsMagick-1.3.9/coders/.deps/coders_tiff_la-tiff.Plo
/usr/lib/GraphicsMagick-1.3.9/coders/magick_libGraphicsMagick_la-tiff.lo
/usr/lib/GraphicsMagick-1.3.9/coders/.libs/magick_libGraphicsMagick_la-tiff.o
/usr/lib/x86_64-linux-gnu/libtiff.a
/usr/lib/x86_64-linux-gnu/libtiff.so.4
/usr/lib/x86_64-linux-gnu/libtiffxx.so.0
/usr/lib/x86_64-linux-gnu/libtiff.la
/usr/lib/x86_64-linux-gnu/libtiffxx.a
/usr/lib/x86_64-linux-gnu/libtiff.so.4.3.4
/usr/lib/x86_64-linux-gnu/libtiffxx.la
/usr/lib/x86_64-linux-gnu/libtiffxx.so.0.0.8
/usr/lib/x86_64-linux-gnu/qt4/plugins/imageformats/libqtiff.so
/usr/lib/x86_64-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-tiff.so
/usr/lib/evince/4/backends/tiffdocument.evince-backend
/usr/lib/evince/4/backends/libtiffdocument.so
/usr/lib/ImageMagick-6.5.7/modules-Q16/coders/tiff.la
/usr/lib/ImageMagick-6.5.7/modules-Q16/coders/tiff.so
/usr/lib/ImageMagick-6.6.9/modules-Q16/coders/tiff.la
/usr/lib/ImageMagick-6.6.9/modules-Q16/coders/tiff.so
/usr/lib/cups/filter/pstotiff
Observer a_mansouri
hi,
if this possibe , how i can link ltiff with vivado hls
Observer a_mansouri
SOLUTION:
REGARDS,
