Visitor sum@
vivado hls synthesis
I have got an error in vivado hls while synthesis process.
ERROR: [HLS 200-70] Compilation errors found:
Pragma processor failed: couldn't create error file for command: permission denied
Failed checking during preprocessing.
while executing
"source E:/suma/Suma/vhdl/hls/hdl/modulator/solution1/csynth.tcl"
invoked from within
"hls::main E:/suma/Suma/vhdl/hls/hdl/modulator/solution1/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Re: vivado hls synthesis
Does the C simulation compile and run properly for your module and the test bench?  If not, concentrate on getting the module and the testbench to compile and run correctly first.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Visitor sum@
Even though i checked several times  iam not able to identify the error please help me where the error is occuring i have attached the code also.
#include "ap_int.h"
#include "math.h"
#include "modulator.h"
// function that calculates sine wave samples value
void init_sine_table(ap_uint<width> *sine)
float temp;
init_sine: for (int i = 0; i < sine_samples; i ++)
// sin (2*pi*i / N) * (2^(width-1) - 1) + 2^(width-1) - 1, N = 2^depth
sine[i] = (ap_uint<width>)(sin(2*3.14*i/sine_samples)*(sine_ampl/2.0-1.0)+sine_ampl/2.0-1.0);
// pwm generator
void modulator(
ap_uint<1> sel, // signal used for selecting frequency
ap_uint<1> *pwm_o) // pointer to pwm output
static ap_uint<depth> counter = 0; // counter for sine wave sample counting
static ap_uint<width> sine[sine_samples]; // samples of the sine wave signal
// sine table initialization
init_sine_table(sine);
// hold pwm_o high for specified number of clock cycles
onloop: for (ap_uint<20> j = 0; j < (ap_uint<20>)(period[sel]*sine[counter]); j++)
*pwm_o = 1;
// hold pwm_o low for specified number of clock cycles
offloop: for (ap_uint<20> j = 0; j < (ap_uint<20>)(period[sel]*(sine_ampl - sine[counter])); j++)
*pwm_o = 0;
counter++;
testbench
#include <iostream>
#include "ap_int.h"
using namespace std;
ap_uint<1> pwm_o; // pulse width modulated signal
int main(int argc, char *argv[])
for (int i = 0; i < 256; i ++)
modulator(0, &pwm_o);
modulator(1, &pwm_o);
return 0;
Ihave wriiten these programs in vivado hls for creating an ip.
Scholar xilinxacct
sum@
Can you also post modulator.h
That being said, I don't think you would get a 'permission denied' from a run of the mill coding error. Have you ever had a successful compilation since you installed?
Also, I don't see any pragmas in the code posted... do you have anything in your directives? If so, are they valid?
Visitor sum@
 I have obtained  sucessful compilation and synthesis  program  .Here is the header file of the modulator.
#ifndef __PWM_H__
#define __PWM_H__
#include "ap_int.h"
#include <cmath>
#define depth 8 // the number of bits used to represent sample count of sine wave
#define width 12 // the number of bits used to represent amplitude value
#define sine_samples 256 // maximum number of samples in one period of the signal
#define sine_ampl 4096 // maximum amplitude value of the sine wave
#define refclk_frequency 100000000 // reference clock frequency (100 MHz)
#define freq_low 1 // first frequency for the PWM signal, specified in Hz
#define freq_high 3.5 // second frequency for the PWM signal, specified in Hz
// minimum duration of high value of pwm signal for two different frequencies
const float period[2] = {(float)(refclk_frequency/(sine_ampl*sine_samples*freq_low)),
(float)(refclk_frequency/(sine_ampl*sine_samples*freq_high))};
// Prototype of top level function for C-synthesis
void modulator(
ap_uint<1> *pwm_o); // pointer to pwm output
#endif
Scholar xilinxacct
sum@
As suspected... I ran the code you provided through Vivado HLS 2018.3 on Windows, and there was no permission denied error. (from synthesis through co-simulation) So, the code is not the problem. It would appear that something about your environment has become corrupted OR a change in permission (as in logging is as a different user) OR the file/folder permissions OR virus protection has made a file nonexecutable, ....
Are you using Linux? If you reinstalled I wonder if the result would change.
Hope that helps
If so, mark as solution accepted. Kudos also welcomed.
