Participant eewse
xf::equalizeHist does not work with pragma dataflow
The following prgram can run on vivado for
TEST001 - TEST004
but for
TEST005
there will produce no output. But why?
#include "axi_sgbm_config.h"
#include "xf_config_params.h"
#include "imgproc/xf_hist_equalize.hpp"
#include "imgproc/xf_duplicateimage.hpp"
#include "imgproc/xf_add_weighted.hpp"
#include "imgproc/xf_convert_bitdepth.hpp"
#include "core/xf_arithm.hpp"
#define TEST005
template <typename T, int rows, int cols>
void drain_xf_mat(T& img) {
    xf::Scalar<1, ap_uint<24>> p;
    for(int i=0; i < rows*cols; i++)
        #pragma HLS pipeline rewind
        //#pragma HLS loop_flatten
        p = img.data[i];
void equalizer(XGRAY_DST_IMAGE& src_disp, XGRAY_DST_IMAGE& src_disp4) {
#pragma HLS dataflow
#pragma HLS inline
    XGRAY_DST_IMAGE src_disp2(dst_rows, dst_cols);
    XGRAY_DST_IMAGE src_disp3(dst_rows, dst_cols);
    #pragma HLS stream variable=src_disp2 dim=1 depth=128
    #pragma HLS stream variable=src_disp3 dim=1 depth=128
    xf::duplicateMat<XF_8UC1, src_rows, src_cols, XF_NPPC1>(src_disp, src_disp2, src_disp3);
    xf::equalizeHist<XF_8UC1, src_rows, src_cols, XF_NPPC1>(src_disp2, src_disp3, src_disp4);
void sgbm_filter_simple(AXI_STREAM& src_data_l, AXI_STREAM& src_data_r, AXI_STREAM& src_data_d)
#pragma HLS INTERFACE axis port=src_data_l
#pragma HLS INTERFACE axis port=src_data_r
#pragma HLS INTERFACE axis port=src_data_d
#pragma HLS stream variable=src_data_l dim=1 depth=64
#pragma HLS stream variable=src_data_r dim=1 depth=64
#pragma HLS stream variable=src_data_d dim=1 depth=64
XGRAY_SRC_IMAGE src_l(src_rows, src_cols);
XGRAY_SRC_IMAGE src_r(src_rows, src_cols);
#pragma HLS stream variable=src_l dim=1 depth=128
#ifdef TEST001
    xf::AXIvideo2xfMat(src_data_l, src_l);
    xf::AXIvideo2xfMat(src_data_r, src_r);
    drain_xf_mat<XGRAY_SRC_IMAGE, src_rows, src_cols>(src_r);
    xf::xfMat2AXIvideo(src_l, src_data_d);
#elif defined(TEST002)
    #pragma HLS stream variable=src_r dim=1 depth=128
    XGRAY_DST_IMAGE src_disp(src_rows, src_cols);
    #pragma HLS stream variable=src_disp dim=1 depth=128
    xf::bitwise_and<XF_8UC1, src_rows, src_cols, XF_NPPC1> (src_l, src_r, src_disp);
    xf::xfMat2AXIvideo(src_disp, src_data_d);
#elif defined(TEST003)
    XGRAY16_DST_IMAGE src_disp16(src_rows, src_cols);
    #pragma HLS stream variable=src_disp16 dim=1 depth=128
    xf::addWeighted<XF_8UC1, XF_16UC1, src_rows, src_cols, XF_NPPC1> (src_l, 0.5, src_r, 0.5, 0., src_disp16);
    xf::convertTo<XF_16UC1, XF_8UC1, src_rows, src_cols, XF_NPPC1> (src_disp16, src_disp, XF_CONVERT_16U_TO_8U, 0);
#elif defined(TEST004)
    XGRAY16_DST_IMAGE src_disp16(dst_rows, dst_cols);
    XGRAY_DST_IMAGE src_disp(dst_rows, dst_cols);
    XGRAY_DST_IMAGE src_disp4(dst_rows, dst_cols);
    #pragma HLS stream variable=src_disp4 dim=1 depth=1024
    #pragma HLS stream variable=src_disp2 dim=1 depth=1024
    #pragma HLS stream variable=src_disp3 dim=1 depth=1024
    //xf::bitwise_and<XF_8UC1, src_rows, src_cols, XF_NPPC1> (src_disp2, src_disp3, src_disp4);
    xf::xfMat2AXIvideo(src_disp4, src_data_d);
#elif defined(TEST005)
#endif
Participant eewse
Re: xf::equalizeHist does not work with pragma dataflow
No need to be too demanding. It won't work even it is only few lines
#include "top.h"
void equalizeHist(AXI_STREAM& src_axi, AXI_STREAM& dst_axi)
#pragma HLS INTERFACE axis port=src_axi
#pragma HLS INTERFACE axis port=dst_axi
XGRAY_SRC_IMAGE  src(src_rows, src_cols);
XGRAY_DST_IMAGE  dst(dst_rows, dst_cols);
XGRAY_DST_IMAGE  dst1(dst_rows, dst_cols);
XGRAY_DST_IMAGE  dst2(dst_rows, dst_cols);
#pragma HLS STREAM variable=src depth=64
#pragma HLS STREAM variable=dst depth=64
#pragma HLS STREAM variable=dst1 depth=64
#pragma HLS STREAM variable=dst2 depth=64
    xf::AXIvideo2xfMat(src_axi, src);
    xf::duplicateMat<XF_8UC1, src_rows, src_cols, XF_NPPC1>(src, dst1, dst2);
    xf::equalizeHist<XF_8UC1, dst_rows, dst_cols, XF_NPPC1>(dst1, dst2, dst);
    xf::xfMat2AXIvideo(dst, dst_axi);
