About ise14.7 using tcl script to build project
In vivado, we can create a project by passing the parameters of <board> and <part> to the led_project.tcl script by typing vivado -mode batch -source led_project.tcl -tclargs <board> <part> in the Tcl Console bar.I want to use the same method to build the project under ise. I try to input source led_project.tcl -tclargs <board> <part> in the Tcl Console of ise but I can't achieve what I want. I found the corresponding document of theise did not find a detailed description. Is there any way to pass the parameters of <board> and <part> to the led_project.tcl script to create the project under ISE?
I refer to Chapter 27 of ug628, but I have not found a way to pass parameters to tcl scripts. I am very grateful to anyone who can help me.
Re: About ise14.7 using tcl script to build project
Hi, owave_hy@163.com ,
Example for using tcl argv in ISE:
Ex: xtclsh ttt.tcl rebuild_project   ("rebuild_project" is the tclargv )
Hi,Does ISE support the "lindex" command, how to use it?
You can use the lindex command in your tcl script.
For the usage info, you can refer to the website for tcl:
https://www.tcl.tk/man/tcl/TclCmd/lindex.htm
Hi,I still have a question.
How to generate a .bin file with the tcl command under ise?
With an option for bitgen command.
Example:
bitgen -g Binary:Yes
I executed the "bitgen -g Binary:Yes" command under ISE, which is not possible.
The following is a screenshot of the test.
bitgen -g Binary:Yes tt.ncd
Please specify your input routed NCD file:
