Access unzip from Vivado TCL
Since Vivado uses zip for such things as .hdf files, I imagine that Vivado TCL has a way to zip/unzip things. Could someone document this so that I can use it in TCL scripts?
Scholar watari
Re: Access unzip from Vivado TCL
Hi @vertreko
Would you use "exec" command as system call operation on Vivado TCL ?
This is basic command in TCL.
@watari, yes that works and something I've done in the past. However, I'm trying to write a script that relies only on having installed Vivado. The specific problem I have is that I would like to unzip the .zip file that vivado_hls creates when you export hardware in "IP Catalog" format.
Scholar watari
i @vertreko
I see.
However I think that it is difficult to find such special command even if tcl is a best way to add new command.
I hope to find what you want to know.
Because of, I'm interesting things, if it is possible.
