ggillett
BD how to find associated clock of a bd_intf_pin?
Is it possible to get from a bd_intf_pin to its Associated clock? Without manipulating path strings.
Can you get to things listed in the General tab using TCL?
Tags (2)
@ggillett
In Vivado, the following Tcl command will return the clock associated with the port/pin called bd_intf_pin.
get_clocks -of_objects [get_ports {bd_intf_pin}]
If bd_intf_pin is a clock pin on a component internal to the FPGA, you can use:
get_clocks -of_objects [get_pins {bd_intf_pin}]
Cheers,
Mark
ggillett
Thanks for the reply.
This does not work. I was not clear that I am talking about block design in IPIntegrator, `"bd_intf_pin" is the class and you use "get_bd_intf_pin path" to get to the object. "get_pins", "get_ports" and "get_clocks" operate on a netlist and at this point there is no open design. There is only a open diagram ie a "current_bd_design"
