BITSTREAM.CONFIG.SPI_BUSWIDTH is not available
we try to set the property BITSTREAM.CONFIG.SPI_BUSWIDTH for a Zynq xc7z020clg484-1 design with Vivado 2013.4. But this property is not accepted in the xdc file. This is the resulting message after the implementation:
  •  [Netlist 29-69] Cannot set property 'BITSTREAM.CONFIG.SPI_BUSWIDTH', because the property does not exist for objects of type 'design'. Resolution: Modify .xdc or RTL to not set this property or move it to a cell that can accept this property
The property (an a lot of others) does also not appear in the Properties window (Netlist window -> "Add Properties").
Also it can not be set in the TCL console with "set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design]".
How can we make this property available?
do you have an open implemented design? Here is what I get during a hardware debug session:
get_property BITSTREAM.CONFIG.SPI_BUSWIDTH [current_design]
4
Thanks for the quick reply.
Yes, I have done the implementation and opened the design. This is the TCL console output when I enter "set_property BITSTREAM.CONFIG.SPI_BUSWIDTH 4 [current_design]":
ERROR: [Netlist 29-69] Cannot set property 'BITSTREAM.CONFIG.SPI_BUSWIDTH', because the property does not exist for objects of type 'design'.
The following BITSTREAM properties can be set (as I mentioned before there are a lot of missing):
These properties for SPI are not applicable for the Zynq devices. They are applicable for 7 series only.
The list you see is filtered based on the appropriate settings for the device you have selected.
Duth
