felixw88
Bug find_bd_objs 2018.2
Zynq7000 Blockdesign, Vivado 2018.2, find_bd_objs does not work in mulitline code or scripts (propagate)
Copy following code to TCL console in open block design
proc find_working {path} { find_bd_objs –relation connected_to [get_bd_intf_pins $path]; }
find_working processing_system7_0/M_AXI_GP0
ERROR: [Common 17-163] Missing value for option 'relation', please type 'find_bd_objs -help' for usage info.
Copy these lines seperately the code does work:
/ps7_0_axi_periph/S00_AXI
This code does never work (added newline in proc function)
proc find_broken {path} { find_bd_objs –relation connected_to [get_bd_intf_pins $path];
find_broken processing_system7_0/M_AXI_GP0
Is there a workaround? Does it work in current version?
Felix
Tags (2)
Reto
Hi @felixw88
I have the same issue. (Vivado 2020.2)
Have you found a solution?
Thank you
Kind regards
Reto Meier
amaccre
Hi @felixw88 , @Reto ,
I have tried this in 2020.1 and 2020.2 and it worked in both cases without error.
Here is the text that I copied in for both versions:
proc find_working {path} { find_bd_objs -relation connected_to [get_bd_intf_pins $path]; }
find_working /v_proc_ss_0/m_axis
proc find_working_1 {path} {
find_working_1 /v_proc_ss_0/m_axis
You can see the steps in the tcl console of the screenshot
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
Reto
Hi @amaccre
Thank you for your answer.
I found the problem: There was a illegal character in the code.
This character was detected early in the process, but Vivado never updated the code. Whatever change I made, did not influence the behavior.
Not sure exactly when the bd/bd.tcl is read and updated. Updating the IP-Repo and upgrade the IP does not help. After a restart of Vivado the changed script seams to be loaded.
Kind regards
Reto Meier
